SolaraGuy.com • View topic - Foggy Headlights
Foggy Headlights
Foggy Headlights
Postby Jillie » Sat Jul 12, 2008 9:49 am
New here :-)
After my 1995 Jeep Cherokee started to show its age, my mom bought herself an 08 Accord and gave me her 2002 Solara... I couldn't be happier :-D It's like a luxurious upgrade for me. So reliable, I get twice the gas mileage and I feel so much safer. It's obviously a little sportier too ;-)
It's and SE... I believe, with some minor modifications, like a spoiler, pin striping, sunroof, power seats, etc. The color is Lunar Metallic.... Very nice car, only 59,000 miles.
My only quips... are the integrity (lots of nicks in the paint from rocks in the road and my neighbor riding her bike too close to the car) but I attribute that to my mother's lack of waxing. Then the head lights, which are turning foggy and yellow. The tail lights, side front lights and fog lights are all clear and bright.
I've seen kits at autozone where you attach a piece to a drill and kind of sand down the exterior of the light. Does this work? How can I tell if the fogginess is caused from the oustide or from the inside?
Anybody else have this problem?
Thanks! Jill
Jillie
Postby Dawgz » Sat Jul 12, 2008 9:59 am
there are alot of products out there that get the job done, just go to a pepboys or watever near ur area.
but for home remedies that work...get white toothpaste, and rub it over the lense(s) till they are covered lightly. u shouldnt have to use too much toothpaste. Let it sit for 10 mins then wash the toothpaste off with warm water. It should be clear now!
works for me on every car ive tried it on.
Postby Solarafreek » Sat Jul 12, 2008 11:38 am
Welcome.
Try Meguires PlastiX (sp). It works but you have to do it like once a month. Ive never tried ^ toothpaste ^. I say try that first since you probably have some, unless you dont brush your teeth. :D
Solarafreek
Postby xan16 » Sat Jul 12, 2008 12:48 pm
x2 for the PlastiX, it is great stuff and will make your headlights like-new again. I picked my bottle up at AutoZone.
2000 Solara SE V6. Autumn Red Mica
[ Eibach lowering springs | Tokico struts | 17x8 wheels | custom exhaust | tint | etc... ]
xan16
Postby Mr_Chunkz » Sat Jul 12, 2008 1:21 pm
I used plastix as well
it definately helps with the fogging but i still noticed some yellowish hue in the lens ( very slight )
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby NeFaRiOuS_SLE » Sat Jul 12, 2008 1:42 pm
Welcome to SolaraGuy!
I personally use metal polish on my headlights, but PlastiX sounds like a better recommendation... But I will have to try the toothpaste since I always find myself re-applying a coat of the stuff every month.
Postby k-0tik » Sun Jul 13, 2008 2:10 am
I did mine today
I used 2000 grit wet sandpaper and plastix.They look like a charm now
k-0tik
Postby QuickSEV6 » Sun Jul 13, 2008 2:58 am
k-0tik wrote:I did mine today
I would think twice before I use a sandpaper. That kind of abrasive is a good way to scratch your lenses. You wouldn't use it on your paint, would you? Why use it on your lenses?
Postby lilm » Sun Jul 13, 2008 10:13 am
High enough grit sandpaper 1500-2500 is actually for automotive paint
lilm
Postby Solarafreek » Sun Jul 13, 2008 11:20 am
I have heard of using wet 1500 then 2k on headlights and using clear after. Also, I would consider using sandpaper on my paint if I was wetsanding....and I wouldnt think twice about it...I am actually considering it. GL with what you decide.
Solarafreek
Postby steffknee » Mon Jul 14, 2008 4:12 pm
I picked up some PlastX and used a buffing wheel drill attachment to buff them. They came our really good. I didn't sand them first though but oh well, maybe next time.
Before:
After:
1997 Toyota Celica ST--my baby/money pit
1999 Toyota Solara SE--now my sister's car
1994 Toyota Celica GT--Beams Swap
steffknee
Postby ClassySolaraGuy » Mon Jul 14, 2008 4:16 pm
Looks good! Nice job cleaning up that grille as well. 8)
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby krook » Mon Jul 14, 2008 4:30 pm
PlastX FTMFW!!
Colgate FTMFT!!!
krook
Postby Jillie » Tue Jul 15, 2008 12:11 am
I went ahead and splurged- I got the 98 cent tube of white colgate- the results are ok... I may try it again tomorrow.
Jillie
