SolaraGuy.com • View topic - too many problems
too many problems
too many problems
Postby 5sfe » Tue Jul 15, 2008 10:52 am
i have mutliple problems with my 99 solara 4cylinder :cry:
everytime i lower my window it scratches my tints and it makes a loud nosie when i lower it like if it was rubbing on somthing
i also how do i fix my seats i dont have alot of money
And theirs water in my trunk i dont know were its coming from
and i here wind nosies in the drive door and passanger this picture is from the driver door
i will appriecate the help..sorry about the small pics its a camra phone
5sfe
Postby 5sfe » Tue Jul 15, 2008 11:04 am
that last pic the rubber thingy whats that called
5sfe
Postby akora12 » Tue Jul 15, 2008 11:21 am
The window problem may be a busted regulator and/or track. On my honda, the cable guide split and rubbed the window as it moved. This ended up destroying my tint. I replaced the whole motor, track, and regulator which is usually sold as a complete assembly.
Postby 00-solara » Tue Jul 15, 2008 11:27 am
As far as water in the trunk:
Has the car ever been rearended?
Do you have a spoiler?
Have you checked the condition of the seals?
2000 Solara SE Diamond White Pearl: 4300K HIDs, Sony H/U, Infinity Kappa 60.5, 693.5i, Two Kicker CVX 10"
00-solara
Postby 5sfe » Tue Jul 15, 2008 11:28 am
i have a rubber pice that my dad gave me he said it goes on the window i was a dum a** and thru it away i wonder what its called my dad left so i cant get a hold to him he said goes on the track of the window he aslo said that it holds the window in place when its moving down so i guess that my window is loose in their..does anybody know whats the rubber pice that goes on the track of the wind which ot holds it in place
5sfe
Postby 5sfe » Tue Jul 15, 2008 11:30 am
i do have a factory wing and it burn out i dont know how to change the lights and yes the factory wing did get water i suppose that how those L.E.D lights got burned
5sfe
Postby 5sfe » Tue Jul 15, 2008 11:31 am
and no my car hasnt been rearended
5sfe
Postby 00-solara » Tue Jul 15, 2008 11:38 am
your car official has more problems then ive ever heard of luckily they're not huge.
you're gonna want to get the trunk dry before it rust out.
if you open the trunk and pull the carpet off of it (the clips should just pull straight out with a lil force)
if you look in the holes you should see some bolts
you might want to check by pouring water around the spoiler on the outside and see if any comes in by those bolts if it does you should reseal the area around them
00-solara
Postby 5sfe » Tue Jul 15, 2008 11:41 am
with what product i should reseal with car with how do i change those l.e.d blubs and were can i buy them
5sfe
Postby 00-solara » Tue Jul 15, 2008 11:45 am
you cuold prolly buy a whole new led bar through the dealership but it could be a lil pricey.
i'm not sure of an exact product but im thinking some general purpose silicon sealant would be find
someone correct me if im wrong or know of a better way...
00-solara
Postby 5sfe » Tue Jul 15, 2008 12:18 pm
i started right away here are some pics
before
and after
i have resolve one problem still have alot to go thanks 00-solara
5sfe
Postby 5sfe » Tue Jul 15, 2008 12:20 pm
5sfe
Postby 5sfe » Tue Jul 15, 2008 12:49 pm
anybody know's were can i get a brand new engine 0 miles new trani new radio which has JBL..all four new seats one new fog light L.E.D bar for my wing and a set of rims 16's by factory i have some carmy rims reallly old iam looking to put everything orginal on my car
5sfe
Postby lilm » Tue Jul 15, 2008 1:40 pm
if it isnt the spoiler and you have a moonroof the water could also be a clogged drainage pipe.
Take off your door trim and see what is rubbing on the window
buy some reconditioning cream for the leather
lilm
Postby NeFaRiOuS_SLE » Wed Jul 16, 2008 10:05 pm
OK here's a couple of tips:
1. PLEASE use proper grammar; it's giving me a headache and I'm sure other members would appreciate it too... Especially if it's a common complaint with newer members of our forum.
2. Try to keep your replies within 1 post if possible. If there's some forgotten detail, go back and hit the "edit" button if nobody has replied yet.
To answer your questions:
Passenger window: It's the regulator/track, sold as a set. The only way to fix it is to replace it; it's cost-prohibitive and damned near impossible to rebuild properly (my driver's side window has a problem with clicking but everything looks fine).
Your seats: If it's torn, I've heard of pastes but heard that they don't work too well. If you want it back to showroom condition, you might as well get new seats, reupholster them, or if you don't mind, put covers over it.
Water in the trunk: If it's leaking from the spoiler like other people have said, there you have it. As far as I know, there's no drainage ports in the tire area (I know that there is one on the left side of the panel that works a little too well; there's always a fresh coat of dirt in there and gets moist when it rains (but I still used it to hide my cigarettes and vodka when I lived with my parents :lol: ... But I've quit smoking and I'm living on my own).
Driver's side window: Looks a bit misaligned; still might be the regulator/track too.
