SolaraGuy.com • View topic - got the CEL codes
got the CEL codes
got the CEL codes
Postby redgen1 » Thu Jul 24, 2008 7:01 am
updated: -
my friend brough in his OBDII this morning, six codes were stored :o
2 of them were p0441
3 were p0440
and one was p0446
i searched and googled it, i know its related to the charcoal canister and evaporation control, but i was wondering if anyone had any more specific insight into the problem..
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby Dawgz » Thu Jul 24, 2008 7:38 am
we wont know untill u post the code u threw.
Have ur friend plug in the OBDII scanner and see what code ur car threw...that will let u know whats goin on.
Postby redgen1 » Thu Jul 24, 2008 8:26 am
yeah i know, im doin it tomorrow morning, i was just wondering if anyone had any sort of ideas about the noise
02 SLE V6
redgen1
Postby redgen1 » Fri Jul 25, 2008 6:10 am
codes are posted
02 SLE V6
redgen1
Postby Midias » Fri Jul 25, 2008 7:36 am
Well p0446 tends to be the canister or the valve on top of it. p0441 is often the gas cap and p0440 usually has to do with the entire system vacuum lines and all so I guess you have a lot of things to check out. I would start with the vacuum lines.
Postby redgen1 » Fri Jul 25, 2008 8:34 am
faaaaaannntastic
02 SLE V6
redgen1
Postby mazen222 » Sat Jul 26, 2008 1:49 pm
i had the 441 and 446 codes... These 2 codes are related. the mechanic told me to fill my tank with supreme gas twice (94 octan) to clean it up and if it doesnt go then come back...
I did that and the check engine went awayafter my tank way half full. It came back after a couple of month and i did the same thing and it went away... since then when i close my gas cap i turn it like 2 rotations after it starts ticking to make sure its completely closed
good luck
1999, 5 Speed V6
mazen222
