SolaraGuy.com • View topic - Gen1 convertibles...please step in.
Postby TLMNICK » Wed Jul 30, 2008 9:16 am
Just wondering if anyone here with a gen1 convertible has ever experienced small leaks through the front door windows. I was driving in the rain today, and only on the driverside i was getting a few drops here and there...any suggestions?
TLMNICK
Postby Chinky420 » Wed Jul 30, 2008 12:21 pm
that has happened on my dad's Z3. it's because the top/weather-stripping is going bad.
the only solution i know of is to replace the top.
but then again, this was on a Z3, not a solara (although the design is the same: window glass all the way up to the convertible top, weather stripping attached to convertible top, no above window door frame)
maybe someone with a lara vert has a different solution/answer. good luck with the fix
Chinky420
Postby TLMNICK » Wed Jul 30, 2008 1:19 pm
I suppose im fortunate in a way because its only leaking through the actual door window, and its not all that much comming in...but its enough to irritate me. I adjusted the rubber a bit so that it sits more snug against the window....i'll see if that helps.
TLMNICK
