SolaraGuy.com • View topic - Need a couple educated opinions
Postby TLMNICK » Sun Aug 03, 2008 10:57 am
I just had a few quick questions that i hope someone can help me with.
1. What octane gas are you guys running in your V-6's? The manual said that 87 is acceptable but that 91 is recommended for optimum performance. My maxima says the same thing, BUT if i did run 87 in the maxima....i'd be going through knock sensors like water, and it runs like crap. Any thoughts?
2. I was thinking about blacking out my corners and headlights. Does anyone here with a Black gen1 have any pics with blacked out headlights they can post?
3. Where can I find clear corners for a Gen1....e-bay was a no-go for me.
TLMNICK
Postby Dawgz » Sun Aug 03, 2008 11:03 am
1. I run 93, but im boosted. But when i first got the car till i was boosted, i ran 87 octane...itll be fine on 87 when ur N/A.
2. I think Tracey has blacked out headlights? (Mr_Chunks)
3. if u cant find them, make ur own? The orange amber part comes out.
Postby BLACK V6 » Sun Aug 03, 2008 4:21 pm
http://www.andysautosport.com/toyota/19 ... _lens/ysd/
31.95 a pair...
Pretty good service too.
BLACK V6
Postby ASG14 » Wed Aug 06, 2008 10:59 am
Same thing as with Dawgz. I'm boosted so running 93, but before that I was running 87 with no issues.
ASG14
Postby conor42 » Wed Aug 06, 2008 4:04 pm
I typically run mid-grade. The ECU doesn't pull timing as badly or at all with 89 in the tank.. Definitely a difference between 87 and 91 (CA high octane..).
If you ever get the chance to hook your car up to a scantool, you can watch the timing advance and see the differences for yourself :)
conor42
Postby 1gSE » Wed Aug 06, 2008 5:22 pm
if i'm gonna pay this much for gas i'm puttin in the good stuff....92 here
Solara-M62 @ 5.5psi
1gSE
Postby TLMNICK » Wed Aug 06, 2008 5:46 pm
Do these cars have knock sensors that go bad if you use 87?
TLMNICK
Postby Ruski » Wed Aug 06, 2008 6:01 pm
i have yet to see a solara knock sensor go bad because of 87 gas, you will be fine to run 87
Postby campfire9 » Wed Aug 06, 2008 6:34 pm
I have run 87 in my 99 v-6 from the day I got it in November of 98. Never had a problem and no knock sensor problem either.
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby DatSRBoi » Wed Aug 06, 2008 6:46 pm
87------------->93 = only 4 dollars more on a tank. Thats basically just not wasting money on ONE greasy wasteful meal a week or one useless mods.
Postby TLMNICK » Wed Aug 06, 2008 6:49 pm
Ok cool. using 87 wont hurt anything....but does running 91, or 94 increase performance or gas mileage at all?
TLMNICK
Postby Ruski » Wed Aug 06, 2008 6:56 pm
i run medium grade on my 04 I4 solara , and i can feel the differance between that and the 87, car runs smoother and less choppy
Postby Jakecallun20 » Wed Aug 06, 2008 8:16 pm
Been runnin 87 fine for a while now. The car was run on 87 by its last owner too, still no problems. Your good.
Postby Midias » Wed Aug 06, 2008 8:21 pm
TLMNICK wrote:Do these cars have knock sensors that go bad if you use 87?
I use 93 have for a long time. I used 87 for about 1.5 weeks and had a knock sensor blow. I do not know if it is related or the sensor just got old but I am back to 93 now. Also I am NA
Postby ThurzNite » Thu Aug 07, 2008 2:47 pm
I had a 97 Maxima, and ran premium all the time. Anything less pings, and performance suffered greatly. Not only that, It had to be Top Tier gas. Maxima was very very picky.
As for the 99 Solara V6 5sp, I've been running premium and works well. I use Chevron and Shell, and tried 76 once. I'm scared to try non-top tier.
For the heck of it, I tried 87 regular. I got 1 more mpg but at the expense of really really crappy performance, and major pinging anytime I loaded the engine. I thought it was a fluke, so I ran another tank of Chevron 87, and same thing happened... mpg stayed at 26 (I've been getting 25 running premium), car has no balls on acceleration, and pings.
Went back to Premium for 2 tanks, and now I'm trying 89 Chevron. It still pings when I push it hard, but performance is nearly as good as premium. And mpg is upper 25. I'll likely stay 89 now, and 91 when I want a lil more fun.
But just to rehash: 87 sucks big time on performance, but got a pretty good jump in mpg. It's a tossup.
ThurzNite
