SolaraGuy.com • View topic - 5w-20 Motor oil
5w-20 Motor oil
5w-20 Motor oil
Postby Jakecallun20 » Fri Aug 08, 2008 7:38 pm
Alright so my question is....Is running 5w20 motor oil in the 1MZ alright, I accidentally picked up 5 qts thinking it needed 5w20, come to find out later that 5w30 is what it said. So I googled around and didn't see any negative problems from the change, so I went ahead and changed it in. The car seems to be running fine. Also seems to accelerate faster, but that is probably just my butt dyno talkin. So I was just curious if anyone knew anything I should be aware of. Thanks, Jake
Postby Jakecallun20 » Fri Aug 08, 2008 9:25 pm
Bump, Anyone have any advice?
Postby TadS » Sat Aug 09, 2008 2:34 pm
That might be a bit thin, but if the motor is in good shape you should be ok. Keep an eye on that oil level to make sure that you're not getting any valve seal leakage, or blow by.
TadS
Postby TLMNICK » Sat Aug 09, 2008 3:36 pm
I suggest going easy on the car till you can change it back to 5W30
TLMNICK
Re: 5w-20 Motor oil
Postby gnegroni » Sat Aug 09, 2008 3:55 pm
Jakecallun20 wrote:Alright so my question is....Is running 5w20 motor oil in the 1MZ alright, I accidentally picked up 5 qts thinking it needed 5w20, come to find out later that 5w30 is what it said. So I googled around and didn't see any negative problems from the change, so I went ahead and changed it in. The car seems to be running fine. Also seems to accelerate faster, but that is probably just my butt dyno talkin. So I was just curious if anyone knew anything I should be aware of. Thanks, Jake
Toyota is recommending 5W20 (not sure if 0W20) on newer 2AZ-FE engines...This might be particularly due to tighter tolerances on engine. It should be fine for now. Oh, and your butt dyno might be right...I tend to feel the difference in engine mode of operation before and right after changing my synthetic oil after 5k miles.
TadS wrote:That might be a bit thin, but if the motor is in good shape you should be ok. Keep an eye on that oil level to make sure that you're not getting any valve seal leakage, or blow by.
I would suggest going back to 5W30 or 10W30 (Toyota recommended for constant Caribbean hot weather). Be wary of the oil level since engine will burn up this oil faster than you are used to. Also keep in mind you are losing protection for the hotter operating range of the engine (stop-and-go traffic, racing, under heavy loads).
gnegroni
Postby steffknee » Sat Aug 09, 2008 7:27 pm
the oil weight just refers to the viscosity of the oil at certain temperatures.
5W20 just means when cold the oil viscosity is rated at 5 and when warm it's rated at 20. It isn't going to make a difference unless you are in an extreme weather environment. Like he said above, if you're in a warmer climate a little higher of an oil weight is a little better.
But there is no harm done in just switching next oil change.
1997 Toyota Celica ST--my baby/money pit
1999 Toyota Solara SE--now my sister's car
1994 Toyota Celica GT--Beams Swap
steffknee
Postby krawzyazn » Sat Aug 09, 2008 7:32 pm
ehh that stuff is pretty thin for your 1mz
Postby BLACK V6 » Sat Aug 09, 2008 7:36 pm
Not to thread jack (lol srry) but i switched to Mobil 1 full synthetic a week ago and I was just wondering if you are supposed to feel a difference in ur cars performance? I really dont... Maybe a lil bit...
BLACK V6
Postby Midias » Sat Aug 09, 2008 9:09 pm
BLACK V6 wrote:Not to thread jack (lol srry) but i switched to Mobil 1 full synthetic a week ago and I was just wondering if you are supposed to feel a difference in ur cars performance? I really dont... Maybe a lil bit...
Probably not but it is just a high quality oil that will help protect your engine.
Postby Jakecallun20 » Sat Aug 09, 2008 10:19 pm
TLMNICK wrote:I suggest going easy on the car till you can change it back to 5W30
Yeah, I switched back today. It sucked, but I couldn't stand knowing the 20 was in there, I could definatley tell the motor was running worse. 103+ degree weather here and with thin oil, just wasn't cutting it. So I took care of it, you guys were thinking everything that was running through my mind. Thanks!
Postby Chinky420 » Sun Aug 10, 2008 1:34 pm
^^ good thing. i was goin to say: these ppl may not know about texas summers.
5w20 is too thin for these weather conditions.
but may be passable during the wintertime.
Chinky420
Postby Jakecallun20 » Sun Aug 10, 2008 11:42 pm
[quote="Chinky420"]^^ good thing. i was goin to say: these ppl may not know about texas summers.
but may be passable during the wintertime.[/quote
Agreed on texas summers, my friend told me that he uses 10W-40 summers and 5W-30 during summers. Idk if I'll do that or not but its something to consider...if 10W will even work with a 1mz.
Postby gnegroni » Sun Aug 10, 2008 11:56 pm
My economy went up a few MPG when I changed from dyno oil to synthetic. I believe in synthetics for its better protection for engine, offering possible longer drain intervals but primarily economy.
gnegroni
Postby Jakecallun20 » Mon Aug 11, 2008 12:02 am
I must not be getting something but I don't understand how oil helps fuel mileage, all it does is lubricate the rotating assembly.
Postby (K) » Mon Aug 11, 2008 12:54 am
Well put it this way, thicker and dirtier oil makes it harder to rotate. Resistance to rotation would mean there's more power required to overcome that resistance. More power means more fuel being consumed.
That's why all your filter's should always be cleaned so all fluids can flow freely and uncontaminated.
As far as the oil weights go, you'd be fine...for now, but I'd suggest changing back to recommended weight as soon as you can. I wouldn't push the engine too hard in it's current state.
If the weight is too low you run the risk of "shearing" much earlier than the 30 weight. Basically the lubricating properties of the oil become nonexistent. Your parts would wear out faster and all that good stuff that follows as a result.
...make-believe scenario: 0 weight oil is practically water (not really, but for this example it is), 30 weight oil is where you want to be. Eventually after a few thousand miles and hard driving, 30 weight loses it's lubricating properties and becomes 0 weight (water); useless. So the closer you get to 0 weight, the less lubricating properties it has (for all intensive purposes we'll say this is true, even though there are many factors that dictate lubrication). 20 weight (less lube) just puts you THAT much closer to 0 weight.
Confused yet?
(K)
