SolaraGuy.com • View topic - Fan only working on speed 3 and 4
Postby mazen222 » Mon Aug 11, 2008 3:00 pm
I have seen a post in the past with the same problem but i couldnt find it.
My air ventillation fan (if thats how u call it) stopped working on speed 1 and 2, but works fine on 3 and 4. I have the knob switch (non digital) system.
How can I fix this? Im freezing with the AC, otherwise i have to be swetting
Thanks guys
update: see post below
mazen222
Postby 5sfe » Mon Aug 11, 2008 9:29 pm
you mean your blower moter...check fuse..and what year is your ride?
5sfe
Postby steffknee » Tue Aug 12, 2008 4:56 am
blower resistor.
1997 Toyota Celica ST--my baby/money pit
1999 Toyota Solara SE--now my sister's car
1994 Toyota Celica GT--Beams Swap
steffknee
Postby mazen222 » Tue Aug 12, 2008 1:43 pm
my car is 1999... with the manual round switches. Any tips on how i can change that resistor? Where is it and whats the type so i can buy a spare? What caused this?
thanks
mazen222
Postby sanborn » Tue Aug 12, 2008 6:21 pm
It's under the passenger side dashboard, close to the centre console I believe. I've replaced it on mine a while back (also manual, turn knobs for heat, etc), very easy.
I think the resistor was something like less than $30 new at a dealership, and it's just a matter of unscrewing and unplugging the old one, and putting in the new one.
sanborn
Postby mazen222 » Fri Aug 22, 2008 3:43 pm
now the thired speed stopped working too... is there a resistor for for each speed? i thought there were only high/low... but now 1-2 and 3 stopped working so...
what might be causing the resistors to burn?
mazen222
Postby mazen222 » Sun Aug 24, 2008 2:52 pm
the mechanic told me its normal since the car is a 99.
the resistor is almost 40$
mazen222
Postby mazen222 » Fri Aug 29, 2008 7:28 pm
I got the resistor and installed it, but now speed 1 and 4 work only. 2 and 3 still dont work.
does it mean that the resistor is deffective or... ?
I did not install it back inside the duct with the screws... i just plugged it and tested it.
btw, the old resistor was all rusted out... looked like crap.
mazen222
Postby cdaniel76 » Fri Sep 26, 2008 2:16 am
mazen222 wrote:I got the resistor and installed it, but now speed 1 and 4 work only. 2 and 3 still dont work.
I'm pretty sure the resistor needs to be installed and secured for it to work.
Resistors will fail in the way you described yours failing. It will start with the low speeds and work its way higher. If it doesn't work once you install it correctly and you're still not getting speeds 2 and 3, I'd try to return it to the dealer. If 1 and 4 are working, either the resistor is defective, or there may be a problem with your blower switch now...
p.s. If your dealer was like the ones I've worked for, it'll be hard to get a refund on the resistor. They don't like taking back electrical parts. However if it is defective, they will give you a new one under warranty. Only problem is, you have to prove it's defective. That usually requires you to have their service department look at it.
-Chris
FORMER Toyota Parts Counterman and Parts Manager
DarCars Toyota(Silver Springs, MD), Bohn Brothers Toyota(Harvey, LA), Toyota of New Orleans(New Orleans, LA) and Toyota of Slidell(Slidell, LA).
cdaniel76
Postby mazen222 » Fri Sep 26, 2008 10:13 am
thx i fixed this.
They had sold me the resistor for the automatic AC switch... I returned it and got the right one from toyota... Works great now!
mazen222
