SolaraGuy.com • View topic - Cabin Air Filter
Cabin Air Filter
Cabin Air Filter
Postby greeensolara » Fri Aug 22, 2008 3:00 am
How to replace the Cabin air filter... It would be great if someone can explain where exactly the filter is at and how to get there. Thanks a lot
greeensolara
Postby lilm » Fri Aug 22, 2008 12:29 pm
we do not have one
lilm
Postby greeensolara » Fri Aug 22, 2008 12:43 pm
hmmm, so what do i do when the ac smells like crap and i cleaned my intake filter? what else can be causing it?
greeensolara
Postby greeensolara » Fri Aug 22, 2008 12:44 pm
may i add... it only smells when the cycle blow is on.. when i have it on the outside air coming in.. it smells normal. very confused on this
greeensolara
Postby lilm » Fri Aug 22, 2008 12:49 pm
get some lysol turn your car on and blow it into the outside vents between the windshield and the hood. There is a plastic cowl with three vents on it one on each side and one in the middle. Spray lysol directly into vents turn the ac on spray it again and keep doing that tll you get rid of the smell.
lilm
Postby Chinky420 » Fri Aug 22, 2008 1:10 pm
i thought our cabin air filter was behind the glove box....?
word on the street is, a sledgehammer will get you to it really quickly.
best bet to check a haynes manual about it...i would do that myself, except i'm at work right now.
Chinky420
Postby lilm » Fri Aug 22, 2008 1:24 pm
lilm
Postby GreenSolara01 » Sat Aug 30, 2008 7:21 pm
lilm wrote:http://www.solaraguy.com/viewtopic.php?t=40176
:agree:
GreenSolara01
