SolaraGuy.com • View topic - Problem with Idle?
Problem with Idle?
Problem with Idle?
Postby PapaDukes027 » Tue Aug 26, 2008 1:40 pm
Ok so heres the problem, the solara isnt hitting like it should. When i'm accelerating from a stop i need to press down on the gas very hard to get the car to take off well. I recently got an oil change and changed the trany oil as well. While the car is idle the RPM arent right....
Its running lower than 1000. If im not mistaken...there is a way to fix the idle myself without taking it into a shop??? I believe the idle is somewhere near here....
Any help would be very appreciated. Thanks guys.
'99 SLE V6
Renova Grill
Injen 2030 Intake
PapaDukes027
idle
Postby Gregtrd » Tue Aug 26, 2008 1:54 pm
Adjust the idle screw, its an allen screw and a 8mm nut, to about 750 to 800 rpm. If your idle still act weird then there something wrong.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby krook » Tue Aug 26, 2008 2:01 pm
check the vacuum hoses as well...that's what it sounds like. or any connectors on the intake
krook
Re: idle
Postby PapaDukes027 » Tue Aug 26, 2008 2:23 pm
Gregtrd wrote:Adjust the idle screw, its an allen screw and a 8mm nut, to about 750 to 800 rpm. If your idle still act weird then there something wrong.
Where exaclty is the idle screw?? Thats what i think it is but im not sure where its located
'99 SLE V6
Renova Grill
Injen 2030 Intake
PapaDukes027
Postby Ilovemylara » Tue Aug 26, 2008 2:26 pm
yeah man the same thing happens to me, only on cold mornings though :(?? where is it at (idle screw)?
Postby Ilovemylara » Tue Aug 26, 2008 3:00 pm
anyone know what it should normally idle at after warmed up?
Postby Ilovemylara » Tue Aug 26, 2008 3:15 pm
no one knows?
Re: Problem with Idle?
Postby Gregtrd » Tue Aug 26, 2008 3:19 pm
The plate that holds the throttle cable has two 10mm bolts just to the left of it is the idle screw
Gregtrd
Postby Midias » Tue Aug 26, 2008 3:25 pm
First why is your check engine light on?
Second try cleaning your throttle body and all the little ports in it and pulling the battery cable to reset the computer on the car.
Finally here is the idle screw there is also one on the other side you can probably get away with just using one but I would make both even.
Personally I would do the idle screw last after fixing the CEL, cleaning the TB and resetting the ECU.
Postby Ilovemylara » Tue Aug 26, 2008 3:28 pm
i agree with midias, fix the CEL first
Postby Gregtrd » Tue Aug 26, 2008 3:35 pm
Midias wrote:First why is your check engine light on?
I've never adjusted the idle screw on the other side of the throttle body.
Gregtrd
Postby PapaDukes027 » Tue Aug 26, 2008 4:24 pm
thanks for the help midas...um throttle body?? sorry kind of a noob under the hood. Wheres the throttle body? Check engine is on because one of my air sensors needs to be replaced.
'99 SLE V6
Renova Grill
Injen 2030 Intake
PapaDukes027
Postby Midias » Tue Aug 26, 2008 4:33 pm
The throttle body s the thing the screw is attached to
Postby PapaDukes027 » Tue Aug 26, 2008 4:37 pm
Aight thanks again midias, huge help bro :D
'99 SLE V6
Renova Grill
Injen 2030 Intake
PapaDukes027
Postby amabsolute » Tue Aug 26, 2008 4:43 pm
my car also idles at six, thats not normal? its been at that since i bought it. any insight would be appreciated
IMG]http://i458.photobucket.com/albums/qq306/amabsolute1/crap-1.jpg[/IMG]
amabsolute
