SolaraGuy.com • View topic - a/c light flashes when driving through water
Postby bassthrive » Wed Aug 27, 2008 8:54 pm
Thanks to fay I have had no choice this past week in doing some water fording. When I hit a patch of water (2-4" deep), about 15 mph, the a/c shuts down and the green a/c led blinks. When I get out and drive a few hundred feet, I can use the a/c again. Anyone ever see this or have more info on it?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby TLMNICK » Wed Aug 27, 2008 8:58 pm
Water is obiously hitting something it shouldnt be....Maybe check all your harnesses at the compressor...make sure they're water tight.
TLMNICK
Postby Pogs » Thu Aug 28, 2008 4:27 am
I dont know about the Solara but I drove my old s10 blazer through a huge puddle.. knocked my serpintine belt out of alignment so I lost power steering, and everything that belt controls for a few moments afterwards.
I think on the Solara there is an accessory belt or something like that. May have knocked it around untill it got back where it was supposed to be.
FYI this may not be what have happened at all...
Search and Win
Pogs
Postby lilm » Thu Aug 28, 2008 12:51 pm
2-4 inches does not seem deep enough to knock off a belt. i thik your shorting out a wire
lilm
Postby DatSRBoi » Thu Aug 28, 2008 1:02 pm
Its just the belt getting wet and not being able to spin the compressor. When that happen the sensor picks that up and blinks the AC light. As soon as it picks up the compressor spinning at the correct rate it kicks your ac back on. Also happens when your AC runs so cold or too low on level that it will do that as a precaution to itself.
There are no shorting of any kind.
Re: a/c light flashes when driving through water
Postby 1gSE » Thu Aug 28, 2008 3:28 pm
bassthrive wrote:Thanks to fay I have had no choice this past week in doing some water fording. When I hit a patch of water (2-4" deep), about 15 mph, the a/c shuts down and the green a/c led blinks. When I get out and drive a few hundred feet, I can use the a/c again. Anyone ever see this or have more info on it?
my car did this once, but it was after a HEAVY rain and a pretty big puddle
Solara-M62 @ 5.5psi
1gSE
Postby bassthrive » Thu Aug 28, 2008 8:21 pm
DatSRBoi wrote:Its just the belt getting wet and not being able to spin the compressor. When that happen the sensor picks that up and blinks the AC light. As soon as it picks up the compressor spinning at the correct rate it kicks your ac back on. Also happens when your AC runs so cold or too low on level that it will do that as a precaution to itself.
Thats what I suspected. Thanks.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
