SolaraGuy.com • View topic - If the rear clunks......
Postby SleeperSolara » Tue Sep 02, 2008 7:25 pm
And it's not the RSB.
It's the strut mount.
My strut mount gave out on me when i was at lunch from school.
This is what the rear strut area is suppose to look like.
This what the top of the strut mount should look like.
This is what the strut mount is suppose to look like from below.
The above is from my passenger side.
Below is the driver side.
This is what i found at school.
This is what the top looked like when apart......
From below......
I suggest to get new strut mounts when you lower your car.
Postby Mr_Chunkz » Tue Sep 02, 2008 9:57 pm
:o
hasnt happened to me
lets pray it doesnt
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Eye8Pussies » Tue Sep 02, 2008 10:07 pm
bearing fell out eh? lol
one of my rear strut mounts finally gave out after 306,000 km, and when I replaced it with my coilovers, it was rusted and literally falling apart...haven't been touched in 6 years since I first lowered the car
Postby GreenSolara01 » Wed Sep 03, 2008 6:55 am
I have had this very same problem. One of my rear struts wasn't torque down all the way. After I put my new shocks on I noticed a little rattle and it kept getting worse. I took the back apart again and the bolt that holds the upper mount to the shock was lose. I tightened it and added a little lock tight.
I would recommend new upper mounts. They are only $20 and you won’t have to worry about it.
GreenSolara01
Postby SleeperSolara » Wed Sep 03, 2008 4:04 pm
Yeah at first i didn't have it torqued down enough..... **oops**
Now i have the rear driver torqued down as far as it would go and it was hard.
The rear passenger strut is blown unfortanely, so i have get a new rear passenger strut.... :(
