SolaraGuy.com • View topic - Fuel specs
Fuel specs
Fuel specs
Postby Jakecallun20 » Mon Sep 22, 2008 8:18 pm
Hey all, If anyone knows...I'd like to know the diameter of stock fuel lines from the firewall to the bottom of the filter, have to do a bit of repair...3/8, 5/8?...etc. Also, is there any kind of line I should look into or away from when it comes to fuel lines? Rubber? Braided...etc.
Thanks, Jake
Postby lilm » Mon Sep 22, 2008 8:32 pm
replace with -06 an lines and convert to return style fuel system....... :o :evilbat: :drinking: :drinking: :drinking: :drinking: :drinking:
j/k :)
lilm
Postby Eye8Pussies » Mon Sep 22, 2008 8:58 pm
the closest you'll find usually is 3/8 (it's actually metric, but very few places carry metric hoses), and just make sure that you get the ones made for high pressure fuel
Postby Jakecallun20 » Tue Sep 23, 2008 9:30 pm
Thanks, I apprecieate that. Got some advice from a friendly mechanic friend, on a repair I can make to my fuel line to make the fuel filter actually...removeable. (its rusted/striped on). So I'll be moving onward with that project before too long.
Postby Eye8Pussies » Wed Sep 24, 2008 9:24 am
sounds good.... good quality high pressure fuel lines and fuel line clamps are a life saver for dealing with many parts of the fuel system!
Postby Midias » Wed Sep 24, 2008 10:44 am
This may help i think I used 5/16 line and compression fittings.
http://www.solaraguy.com/viewtopic.php?t=37263
