SolaraGuy.com • View topic - Tire size
Tire size
Tire size
Postby octavian » Wed Sep 24, 2008 10:24 am
I have a 2003 solara with 16 inch wheels and purchased 2007 toyota rims which are 17x7. I looked up the 2007 rims on a website for tires and there recommendation is 215x45's, another site states, 215x50. The offset of these 2007 wheels is 45. What would be the most logical size to use.
octavian
Postby ThatVietGuy » Wed Sep 24, 2008 12:59 pm
215/50/17 is the closest you can get to the factory diameter of the OEM wheels and therefore should be the best choice.
ThatVietGuy
Postby SleeperSolara » Wed Sep 24, 2008 2:51 pm
You can also squeeze 225/45.
Postby BChad200 » Wed Sep 24, 2008 8:24 pm
ThatVietGuy wrote:215/50/17 is the closest you can get to the factory diameter of the OEM wheels and therefore should be the best choice.
yup, this is the best choice. it's actually a smidge bigger than stock diameter. you can play around with this to experiment with different tire sizes.
http://www.miata.net/garage/tirecalc.html
2000 Solara SE V6 5 speed- driven for fun
1994 Mazda B3000 SE Cab Plus 2wd Auto- driven for everything else
BChad200
