Can I use V6 Battery on my V4 Solara
HI, I can't find Solara V4 Battery at Costco. can i use V6 battery instead?
Thanks
Thanks
- dciso
- Just Licensed SolaraGuy
Gangis wrote:Welcome... I don't think there's a difference in the battery between the two engines. Also, the 4 cylinder (5S-FE and 2AZ-FE) engines are I4 not V4.Just a heads up!
The letter shows how the engine's designed... our 4cyl engines have 4 cylinders in a row, hence I4. The V6 has 3 cylinders in two rows and when you look at it from the side, it looks like a V, hence V6. Four cylinders in two rows in a V means a V8. There's also W16 which is basically 2 V8s bolted together.
Hope this made things a bit clearer for you.
dciso wrote:HI, I can't find Solara V4 Battery at Costco. can i use V6 battery instead?
Thanks
onefiend wrote:Dawgz wrote:
guess what that is?
George Foreman Grill?
