SolaraGuy.com • View topic - Automatic headlights
Postby ThurzNite » Sat Nov 01, 2008 4:23 pm
I want my automatic headlights to come on earlier. When I'm in an underground garage, sometimes the haedlights don't come on (not dark enough) but I want them to. And today it's raining, but the lights don't come on (DRL works, but I want headlights). How do I change the sensitivity of the sensor? Thanks!
ThurzNite
Postby 1gSE » Sat Nov 01, 2008 4:32 pm
just reach up and twist the headlight switch........ :-?
Solara-M62 @ 5.5psi
1gSE
Postby TLMNICK » Sat Nov 01, 2008 4:47 pm
Find someone who tints windows....and put a small piece of 35% tint over the light sensor on the dash....it'll trick the car into thinking that its darker than it really is.
Doing this though will proably make it come on on a more than normal cloudy day..and it will for sure come on underground.
TLMNICK
Postby Dawgz » Sat Nov 01, 2008 5:18 pm
TLMNICK wrote:Find someone who tints windows....and put a small piece of 35% tint over the light sensor on the dash....it'll trick the car into thinking that its darker than it really is.
Dono if that would work...but interesting idea!...he should give it a try, its pretty logical.
Postby mazen222 » Sat Nov 01, 2008 7:53 pm
yup, that tint idea would defenatly work, but be carful not to make too dark
1999, 5 Speed V6
mazen222
Postby ThurzNite » Sat Nov 01, 2008 11:35 pm
Thanks for the replies. They're great ideas. I was hoping for something more transparent and less 'MacGyver-ish'. Is there a way to reprogram the sensitivity? Thanks!
ThurzNite
Postby Jakecallun20 » Sat Nov 01, 2008 11:44 pm
Cool idea, but too much work for such a small thing, when you could just turn the headlight switch.
Postby TLMNICK » Sun Nov 02, 2008 2:15 am
ThurzNite wrote:Thanks for the replies. They're great ideas. I was hoping for something more transparent and less 'MacGyver-ish'. Is there a way to reprogram the sensitivity? Thanks!
There is no way to adjust the sensitivity of the light sensor. If putting a small piece of tint it too much work, I suggest just using your light switch as suggested above.
Truthfully, I think that trying to find a way to reprogram the headlight module would take a lot more time.
TLMNICK
Postby ThurzNite » Sun Nov 02, 2008 8:58 am
Do any of you guys have the RS3000 security system? I thought I saw it in the programming manual in there. But I don't have access to the manual. Can somebody check that for me? thanks.
ThurzNite
Postby ThurzNite » Tue Nov 04, 2008 1:23 pm
Nevermind, non-adjustable, unless I change the sensor. I'll see about doing that.
ThurzNite
Postby NeFaRiOuS_SLE » Wed Nov 05, 2008 12:49 am
Yeah, it's a rather nice concept; but taking nearly 30 seconds to activate/deactivate is a bit far fetched compared to what you see in newer cars... But then again that's coming from a person who's too tired to just flip the damned switch after 8 hours of work + the occasional 3 hours overtime after work, or well... By the time the automatic headlights kick in during a tunnel or an underpass with a long signal, you're already out and back into sunlight, thus almost defeating the purpose.
Heck, I've even went to the LAX underpass without the lights turning on on time (I was 1 second away from the other end), and that's the longest underpass I've been in!
Postby Sentinel » Wed Nov 05, 2008 9:31 am
I just leave my headlights on all the time.
I haven't had a problem burning bulbs with the extended use, and B/C the car shuts them off automatically I never have to worry about it.
Sentinel
Postby ThurzNite » Fri Jan 16, 2009 11:04 pm
I'm thinking of leaving mine on all the time... but I sorta like the 35 watt city lights, instead of full on headlights.
ThurzNite
