SolaraGuy.com • View topic - Faaaaast corners
Faaaaast corners
Faaaaast corners
Postby badjura » Thu Nov 06, 2008 9:45 am
and on pops my emergency brake lite. When I straighten out, it goes off again. Maybe my cars signal for me to slow down :-?
2002 SE 2.4_TRD Kit - BBS
badjura
Postby Got2XLR8 NYX » Thu Nov 06, 2008 9:49 am
maybe you need to top off your brake fluid
5Speed 2000 SC V6 @ 4.5PSI
Got2XLR8 NYX
Postby YESCA » Thu Nov 06, 2008 10:10 am
Yup... Your brake fluid is low. Top it off and you will be fine. :fadein:
YESCA
Postby badjura » Thu Nov 06, 2008 10:17 am
thanks guys - i'll check it out
badjura
Postby Mole » Fri Nov 07, 2008 1:01 am
top off your blinker fluid as well.
Postby QuickSEV6 » Fri Nov 07, 2008 1:07 am
Mole wrote:top off your blinker fluid as well.
You can find that here:
http://kalecoauto.com/
They also have cross drilled brake lines and muffler bearings.
Postby badjura » Fri Nov 07, 2008 12:08 pm
:lol:
badjura
Postby SpeedySolara » Mon Nov 10, 2008 7:44 pm
If you top off your fluid and the light still comes on turns that means your brake pads are low so start shopping for them.
SpeedySolara
Postby badjura » Wed Nov 19, 2008 12:43 pm
Finally pickup 6 bucks with of brake fluid & problem solved. Blinker fluid checked out ok ;-) Thx guys
badjura
Postby solaratony » Fri Dec 05, 2008 8:30 am
Mine did that for the longest time. Had me really worried. Fluid was fine. Replaced the pads in september, and no more light. I never knew that the brake light would come on because of the pads.
99 SLE V6
solaratony
Postby Donnie » Fri Dec 05, 2008 8:58 am
IDid you top off your brake fluid while you were under the hood?
Bwahahahahahhhh....... cough cough ...........i kill me sometimes.
Donnie
Postby 99SLE-S » Sun Dec 14, 2008 1:45 pm
SpeedySolara wrote:If you top off your fluid and the light still comes on turns that means your brake pads are low so start shopping for them.
For me the brake light is on almost all the time, except for under acceleration and sometimes around a corner. The brake fluid is fine. I don't see how the body moving would shut the sensor off if it was for the brake pads.
Any insight?
1999 DWP Toyota Solara SLE-V6 w/Sport Package
Planning on TRD springs/Tokico shocks/wheel spacers(rear only)
99SLE-S
