SolaraGuy.com • View topic - Traction Control Question .... opinions please
Postby MetrowestLara » Fri Nov 07, 2008 8:52 am
I just noticed that me traction control switch doesn't appear to be working and I was wondering if that means my traction control isn't working. When I turn the key in the ignition I do get the traction control light and trac off light to come on. They go off in a few seconds as they are supposed to. So I don't think it's an issue with the lamps not working. I checked my owners manual for a possible fuse issue but didn't see a circuit specifically for the traction control. The fuses where traction control is mentioned are also fuses for other guages and instruments and those are all wokring. Has anybody had this issue before? If you did what was the issue or am I worrying about nothing? Is there a dedicated fuse for the traction control? By the way I have Gen 1 Solara, 6 cylc SLE.
MetrowestLara
Postby SpeedySolara » Fri Nov 07, 2008 9:00 am
I dont know where the fuse could be but here's an inexpensive way, yet stupid way of finding out if your traction control works:
Peel out and if your traction control kicks in, then its working and vice versa. If you dont have enough power to make the wheels spin, do it on a slippery surface (or a rainy day). I wouldn't recommend pulling the hand brake up and accelerating but thats another way. Good luck and hopefully someone could give a smarter answer. :drinking:
SpeedySolara
Postby MetrowestLara » Sun Nov 09, 2008 6:20 pm
Well looks like the TC is working OK. It was raining up my way and tried a quick get away and the taction control kicked in. This leaves me to believe I have a bad switch or a wire is come loose. Anyone know how to remove the cetner console? I hate having things in my car that should be working but aren't.
MetrowestLara
Postby 99SLE-S » Tue Nov 18, 2008 2:09 am
Was traction control an option?
1999 DWP Toyota Solara SLE-V6 w/Sport Package
Planning on TRD springs/Tokico shocks/wheel spacers(rear only)
99SLE-S
Postby Eye8Pussies » Tue Nov 18, 2008 2:17 am
yup, it was an option only available on the SLE if the original owner paid extra for it
Postby JavaJoe_2 » Tue Nov 18, 2008 5:31 am
I think it's a pita, how can I disable it? The only way I can think of is by replacing the ecu. Any other ideas?
Got Boost?? :sweet:
JavaJoe_2
Postby Eye8Pussies » Tue Nov 18, 2008 11:39 am
...by pressing the TRAC button? lol and yeah, replacing the ecu with a non traction control ecu would work too I would think
Postby JavaJoe_2 » Tue Nov 18, 2008 9:12 pm
Eye8Pussies wrote:...by pressing the TRAC button? lol and yeah, replacing the ecu with a non traction control ecu would work too I would think
LOL, Yeah Thanks. I meant permanently. :drinking:
Got Boost?? :sweet:
JavaJoe_2
Postby 99SLE-S » Fri Nov 21, 2008 4:59 pm
Eye8Pussies wrote:yup, it was an option only available on the SLE if the original owner paid extra for it
Thanks for the clarification :up:
99SLE-S
Postby Eye8Pussies » Fri Nov 21, 2008 6:29 pm
get a different tranny ecu that never had traction control and that should do it!
Postby RandySolara » Fri Dec 05, 2008 7:06 am
MetrowestLara wrote:Well looks like the TC is working OK. It was raining up my way and tried a quick get away and the taction control kicked in. This leaves me to believe I have a bad switch or a wire is come loose. Anyone know how to remove the cetner console? I hate having things in my car that should be working but aren't.
If TC is working fine, why do u wanna remove it ? just ignore the censor-light, this happened to some of Solara99-00 SLE v6, i used to drove a 99Solara SLE V6 for couple years, yes i got anoying censor lights like you, i brought to Toyota dealer, they said nothin wrong just the censor problem and no need to worry, but keep the TC mode on it helps the car steady when in WET or SNOW and Slippery, there are some normal situations while driving a Solara, when you makin a hard turns left/right, usually when in underground parkin you'll hear the wreck-wreck weird sound, i wasnt sure but one of my machanic friend says, Solara 99-21 are like that, he checked and nothin wrong. I think ! maybe the ABS and Traction Control.....
And Traction Control is available on all SLE V6 solara.
RandySolara
BAN sticked
