SolaraGuy.com • View topic - Clutch Pedal Switches
Postby KILLA CAM » Thu Nov 13, 2008 8:07 pm
If you look at the clutch pedal there are two switches: one at the bottom and one at the top. I know that the bottom switch is the clutch start switch, but can anyone tell me what the top switch is called, or is for?
Thanks
-Killa
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby (K) » Thu Nov 13, 2008 8:21 pm
I believe it's Cruise Control, my buddy's Sentra had an issue with that dangling down...if you step on the clutch the cruise control would still be activated. That's not supposed to happen.
(K)
Postby Jakecallun20 » Thu Nov 13, 2008 9:22 pm
Wait, you have a clutch start cancel switch....in a car? A camry??
Postby NeFaRiOuS_SLE » Thu Nov 13, 2008 10:24 pm
I'm sure he meant one that's near the clutch pedal itself, not a switch on the dashboard. In most cases it is the cruise control cancel.
