SolaraGuy.com • View topic - Fuel injection cleaning
Postby rossman945 » Sat Nov 15, 2008 11:22 am
I was at tiresplus the other day and they said I need a fuel system cleaning, fuel injector cleaning etc. The car has 110000 miles and it hasn't been done but the cars running fine, should I just get something from advanced auto parts, dump it in the tank and call it a day? Whatever their going to do I dont think it will be worth 70 bucks. Any opinions would be great.
Thanks,
Ross
rossman945
Postby System_Crash » Sat Nov 15, 2008 11:55 am
It depends on the shop, but fuel system "Injecter flush" IE: hooking a flush machine to the fuel rail and pull the fuel pump relay out and run the vehicle off of the "fuel flush" for about 15-30 mins. Some just clean the throttle body and spray the rest of the can into the intake. and $70 is cheap for a "flush"
Pearl White 2004 Solara V6 90,000 miles
System_Crash
Postby Ilovemylara » Sat Nov 15, 2008 11:56 am
Don't buy those stupid fuel injector cleaner bottles.. they may help a little... but nothing compares to pulling the fuel rails off and hand cleaning the injectors.
Postby rossman945 » Sat Nov 15, 2008 12:00 pm
yeah, well I have a intake on my car and dont want them messing with it, besides I have cleaned my throttle body before, its not bad. Actually flushing the rail and injectors seems more benefical and is beyond my preventative maintenace capabilities. I figured dumping some stuff in the fuel tank will do just the same job.
rossman945
Postby rossman945 » Sat Nov 15, 2008 12:02 pm
well I'm starting to sense a concensus here, I guess I'll get it done the right way and get some estimates.
rossman945
Postby gnegroni » Sat Nov 15, 2008 12:06 pm
System_Crash wrote:It depends on the shop, but fuel system "Injecter flush" IE: hooking a flush machine to the fuel rail and pull the fuel pump relay out and run the vehicle off of the "fuel flush" for about 15-30 mins. Some just clean the throttle body and spray the rest of the can into the intake. and $70 is cheap for a "flush"
In nearby shopping center they use throttle body cleaner and a fluid they put thru brake booster...I can do this at home (read SeaFoam). How much should they charge for this machine clean directly in the fuel rails?
Ilovemylara wrote:Don't buy those stupid fuel injector cleaner bottles.. they may help a little... but nothing compares to pulling the fuel rails off and hand cleaning the injectors.
Wow, how much would they charge for hand cleaning the injectors?
gnegroni
