SolaraGuy.com • View topic - Diagnosed today - Help please!
Postby ninetynine » Tue Nov 18, 2008 5:43 pm
Hey guys! I'm hoping I can get some help regarding the exact name on a part that went bad. The dealer listed that my Idle Control Valve is faulty. My '99 V6 SE 5spd recently will not stay on idle, when I start it. It starts right up but will die off, so I keep the foot on the gas, which eventually helps the idle stay on point. The idle is steady from there and doesn't fluctuate at all.
Please let me know if anyone knows the correct part name and maybe number too? I Google'd it and looked under genuine parts and did not recognize "Idle Control Valve". Thanks in advance!
-Alan
'99 SE V6 MT Silverstream Opalescent - DD
Paddling out and Cars
ninetynine
Postby .onetohate » Tue Nov 18, 2008 6:46 pm
he's talking about the IAC Valve.
.onetohate
Postby Midias » Tue Nov 18, 2008 8:08 pm
Should be the idle air control valve I would get some throttle body cleaner and clean it out really good before buying a new one. Take the throttle body off and spray it down really good clean all the black crap out.
Postby Midias » Tue Nov 18, 2008 8:10 pm
From Autozone
Duralast / Idle Air Control Valve
for a 1999 Toyota Camry Solara
Part Number: AC415
Weight: 0.69 lbs.
Warranty: 2 YR
Application: With manual transmission
Pricing: $219.99
Postby ninetynine » Tue Nov 18, 2008 9:53 pm
Whoaw... thanks for the tip on cleaning it out first! That price is still expensive, even at Autozone. Btw, it was weird because I typed in IACV on the OEM Toyota parts online stores and it never recognized it - typed out or abbreviated. Hmm, oh well. Thanks again for the feedback!
ninetynine
Postby Akfahad » Wed Nov 19, 2008 7:53 am
even after cleaning mine out, I still had to replace mine when that happened to me...but still worth a shot for sure.
Postby Midias » Wed Nov 19, 2008 8:19 am
^ Yea sometimes you get lucky. For my wife's Camry I thought I would have to replace it after trying to clean it with the throttle body still attached. When I too the TB off and cleaned the sensor out and all the passages the car worked normal again.
Postby NVDIS1 » Wed Nov 19, 2008 10:13 am
Toyota part #'s
IAC valve 22270-20020 can do $175 shipped
gasket 22215-20010 can do $3.50 shipped
$178.50 shipped USD
and in stock...ordered one for my ride but wasn't my problem
Postby ninetynine » Wed Nov 19, 2008 1:05 pm
NVDIS1 wrote:Toyota part #'s
$178.50 shipped USD
Hmm... Let me get to cleaning it out first and if that fails I'll definitely consider this. Thanks.
ninetynine
