SolaraGuy.com • View topic - How do I clear ABS codes on 99 Solara SLE?
Postby kaarona1 » Thu Nov 20, 2008 8:02 pm
I remember seeing it a while ago. Something like unhook batter and pump brakes fast... Anyone know? Thanks!
kaarona1
Postby Jai_Jai_Binks » Fri Nov 21, 2008 12:34 pm
^^ by replacing your ABS sensors! (possbly check into that!). I think the reason they are on is cus something is off. You can band-aid the issue or solve it!
Postby Mole » Fri Nov 21, 2008 5:45 pm
you can try resetting the computer, but if there is a problem, it will persist...
problems don't fix themselves.
Postby campfire9 » Fri Nov 21, 2008 6:58 pm
Did you check your brake fluid level?
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby Jai_Jai_Binks » Sat Nov 22, 2008 10:44 am
^^ Lack of fluid leads to brake light not ABS light
Postby kaarona1 » Mon Dec 01, 2008 12:28 pm
I understand that I need to fix the problem. thanks for the insight! I was just trying to clear the codes since I put a used ABS sensor in. I figured out how to clear the codes by the way. I guess as our Gen1s get older and people get new cars, the quality of help starts to fade also. Thanks anyway.
kaarona1
