SolaraGuy.com • View topic - OEM Flywheel
OEM Flywheel
OEM Flywheel
Postby ninetynine » Fri Dec 05, 2008 1:46 pm
Hey guys! I checked the Search link but could not find the answer... So here it goes; I am purchasing the OEM Exedy/Daiken Clutch Kit, and looking for the OEM flywheel. I Google'd and haven't found a thing on it. I have found a ton of clutch kits for my 99' SE V6, but nothing on the flywheel.
Any alternatives that will work besides the OEM flywheel with a stock feel to it? Also, I know I can easily have the original resurfaced, but decided on just getting a new one. Thanks in advance for the help!
'99 SE V6 MT Silverstream Opalescent - DD
Paddling out and Cars
ninetynine
Postby Eye8Pussies » Fri Dec 05, 2008 4:29 pm
nope, no other options I believe....though, if you check on ebay, you may be able to find an aftermarket alternative if I remember correctly
Postby ninetynine » Fri Dec 05, 2008 11:52 pm
Eye8Pussies wrote:nope, no other options I believe....though, if you check on ebay, you may be able to find an aftermarket alternative if I remember correctly
Thanks for replying. I ended up with geniune parts for everything, discounted at the dealer parts store. I figured, I couldn't go wrong with these parts. Thanks again.
ninetynine
Postby ThurzNite » Thu Dec 18, 2008 12:00 am
I would take it to a machine shop and get it cross drilled or slotted for weight reduction and dissipation of heat/gasses. :)
ThurzNite
Postby 1gSE » Thu Dec 18, 2008 6:44 am
wtf...its a flywheel not a brake rotor
Solara-M62 @ 5.5psi
1gSE
Postby Midias » Thu Dec 18, 2008 7:21 am
Nice I think when the time comes I am going with a fidzana wheel
