SolaraGuy.com • View topic - accelaraction problemo
Postby wid » Wed Dec 10, 2008 8:28 am
when i drive my at about any speed and floor it the my car does not react and stutters and wheni lift my foot from thw pedal and gas again its fine again is it me and how i push my car or is it me car vehicle
wid
Postby Biggi_e » Wed Dec 10, 2008 8:44 am
where are you from?
Postby no_escape » Wed Dec 10, 2008 9:21 am
Check the gap on your plugs,
Clean your Throttle Body butterfly,
Check your air filter,
Clean you fuel injectors.
Just afew things you should go over. If it's not them, come back and someone will give you more areas to check onver on your car.
no_escape
Postby wid » Wed Dec 10, 2008 9:37 am
florida
wid
Postby Chinky420 » Wed Dec 10, 2008 2:50 pm
you drive a 4 cyl. lay off the accellerator and enjoy the savings at the gas pump
Chinky420
Postby Biggi_e » Wed Dec 10, 2008 3:01 pm
learn how to type buddy..esp spell check lol
as for your car like chinky420 said..its a 4 cylinder..not going to go anywhere..
Postby Midias » Wed Dec 10, 2008 3:22 pm
Regardless of power it should still be fairly smooth when was your last tune up?
Postby TadS » Wed Dec 10, 2008 4:51 pm
Any CEL? Sounds like it could be fuel mix problem. My '89 Celica was laggy as heck for a while, it was the 02 sensor.
TadS
Postby SleeperSolara » Wed Dec 10, 2008 5:29 pm
Chinky420 wrote:you drive a 4 cyl. lay off the accellerator and enjoy the savings at the gas pump
Bwahahaha.
Great way to put it.
Postby wid » Wed Dec 17, 2008 8:32 am
my last tune up was about a week ago and the messed up part is, my car has gotten even worst. the rpm was high and the car had trouble acclerating, but i took to the toyo dealers asap they said it was caused by damage wires and my exhuast does not give enough space for emmissions to comes out i dont know. they fixed my car for 88 bucks and told me that they just repaired the wiring but my piping under the car is not looking so good. The dude said its ok to drive now but i order for me to fix the exhaust problem it will cost me about 800 Smacks but my goal is to save up for the kamanari lip kit but i geuss a cars health comes first before looks.right? ... :(
wid
Postby Midias » Wed Dec 17, 2008 8:36 am
Are they going to replace the spark plug wires? It is possible when you replaced your plugs you broke the wire ends it happens often. That is why I always lube mine with dielectric grease and coat the plug threads with anti seize. If that is the problem you can do that easily. What do you mean by piping health do you mean the flex pipe is rusting through or the catback is falling apart? I would bet on the flex pipe but either way there are easy fixes for much less than 800 dollars.
Also can you please read your posts over before you hit submit they are very hard to read.
Re: accelaraction problemo
Postby RandySolara » Wed Dec 17, 2008 10:42 am
wid wrote:when i drive my at about any speed and floor it the my car does not react and stutters and wheni lift my foot from thw pedal and gas again its fine again is it me and how i push my car or is it me car vehicle
This happened to my Solara 99, lol its happened sometimes in the 4/ways Intersection whenever i wanna pass the bus or someone beside, you know how my car was like, it was HOPPING like dancing Hip-Hop style haahahah, downtown Toronto is bunch of peoples, everyone looked at my car and was like,, wah-da......i did the same like you Wid, released the Pad and gas slowly again it was fine ;) the 1st time it happened i asked machanic guy, he said cause i Gas tooooo fast this usually happens to some of Old gen Solara, he was right man, i did Gas very fast and deeply the gas-pedal, well 1st of all i didnt believe and ive tried again, sometimes it happened the same, he checked my car he says nothing wrong, but for you i dont know how it happened to your car, did it happened while you were stopped at traffic like or while you were tryin to spin the wheel ? any speed ? hmmm i think you need to take it eazy on Accelaration (gas pedal)
This has nothin to do with 88$ and 800$ whatever Toyo guy told you, some bad dudes they screw it up and draw it more to make more money of you, where did you TUned-Up your car though ? Toyo ? you meant Toyota dealer ?
RandySolara
BAN sticked
Postby Chinky420 » Thu Dec 18, 2008 11:34 am
RandySolara wrote:it was HOPPING like dancing Hip-Hop style haahahah, downtown Toronto is bunch of peoples, everyone looked at my car and was like,, wah-da......i did the same like you Wid, released the Pad and gas slowly again it was fine ;)
what you're describing randy sounds more like what i would call 'wheel hop.' which is, when you floor it, you feel your front wheels jumping up and down as they try and get traction. and for anyone outside of the car, it looks like the solara is trying to shake itself apart. yes?
well, i'm not exactly sure that this is what wid is talking about. wid sounds like he's describing some sort of engine lag due to something or another (context clue: "when i drive my car at any speed and floor it"). and also, i'm not sure if the 4cyl would be able to produce enough torque to have wheel hop. wid: i'd def do a complete tune up. fluids (oil, tranny, coolant), filters (oil, air, maybe fuel), spark plugs and wires. also, clean out your throttle body and your MAF sensor (both have specific aerosols at autozone that you can buy, both by STP if i'm not mistaken), and if you have the inclination, clean out your intake plenum too (it's probably really dirty).
randy, if i'm not mistaken, your problem only happens when doing a hard launch from a stop, right? if so, then you should know that you can help reduce wheel hop by upgrading your engine mounts, and your transmission torque rod. i used to have the same problem (bad), but once i upgraded my torque rod, i almost completely eliminated any wheel hop from hard launches (it still happens if i power brake to a certain specific RPM and launch, but if i'm just flooring it, i break traction and light up the tires).
wid: also, if you have an automatic tranny, you may be getting stuck in between gears, and you might want to have that checked out by a mechanic. it sounds like it could be the same symptoms that i just had looked at on my 99 sle. basically, i could drive it and everything, but if i was trying to scoot along a little bit faster, i would feel/hear my car 'downshift' but i wouldn't feel any power. basically, what was happening to mine was that the gear would disengage, and i would essentially be stuck in between gears (the tranny was hunting for the right gear, it would go to the next gear up, then back to the previous gear, and back again, until i layed off the accelerator). basically, my auto was slipping really badly, and it was not only noticable, it was dangerously unpredicatable.
try this: take a drive where you can push your car (highway, or deserted straightaway), and push her until you feel your problem. try to isolate the circumstances that are causing it (i.e. a certain point in the powerband, a certain speed, or just all the time).
then, do the same drive, only this time, shift between L-2-D and see if you are able to get all the way through the gears (and to an ideal speed) without having the problem.
when i did the ridealong with my tranny mechanic, this was basically what he did to determine if it was a problem with other drivetrain components, or if it had to do with my transmission overdrive system (which is slightly different from the OD button on the shifter). the overdrive system (in transmission mechanic lingo) is the system that controls the upshifting, and by doing it 'manually', you can discern if it's a problem with the tranny, or with other parts of the drivetrain. to my surprise, i (as a lay person) was able to notice that 'manually' shifting L-2-D prevented it from going into gear-hunting-slippage.
the other thing my tranny mech did when i was riding along was put it in L and powerbrake the hell out of it. he said it was to check slippage and torque converter stall, but i didn't really understand it's importance to diagnosing problems, so i wouldn't recommend you to do it, since i can't really tell you anything to look for when doing this (and it causes unnecessary wear and tear on the tranny)
BUT - if what i described sounds like it could be the culprit, i hate to tell you, but i replaced my tranny (and you may have to do the same)
as much as i can recall, my mech said i had a bad forward drum, and it was leaking fluid into something or another and causing too much pressure for another thing to engage. or something. (not very helpful, i know). basically, he gave me two options: 1) short term (~$900) fix the drum and it'll be good for about another year, or 2) long term ($1355) replace the tranny with another.
i was lucky enough to find a used tranny with 67k miles on it for $600 in a scrap yard. if i didnt find that, i may have actually gone through with a manual swap (which was option 3, i had just finished paying off the car so i didn't want to sell it yet, so sinking $5k into it for a manual was almost a possibility...option 1 would only have been if i wanted it fixed and running to sell). oh yeah, and i also had a carrier bearing and an axle seized together.
you being a 4 cyl, i wouldn't recommend a manual swap, it's just not worth the money for the limited potential of the car. but be aware that it may be a tranny problem if everything else turns out ok.
(see the things i'll do to take up my time instead of work :lol:)
Chinky420
Postby Chinky420 » Thu Dec 18, 2008 11:36 am
follow up to the above, i dont think the 4cyl has a MAF sensor, so nix that part.
Chinky420
Postby RandySolara » Sat Dec 20, 2008 2:03 pm
No not the wheel hop bro it was Engine lagged, as you stated up there, due to the gear changin too fast it messed up and make the car Hoppin, the 1st time it was bad untill ive talked to the mech guy, it wont happen if i wait to gear 3 and press harder, My Solara99 is SLEv6 fully loaded, the car was fast like Supercharged Engine, i scared out Ford-Mustang, Acura-Integra, Honda Civic-si, Tied = to a Lexus 4D sport-sedan, i didnt pay attention what model was it. But that Luxus was crazy than my Solara.
Honestly i wasnt sure what was up to the Solara, the Engine say "Camry 24Vales V6" nothing is different to Camry Engine year 92-96 and what ive seen by drivin the 99-01 Solara, it faster than most of Sport-Coupe car and it can be compared to some of 5spd sport-coupe for drag-race. Seriouly in downtown Toronto whenever i wanna pass someone or pass a TTC-Bus, Lady-Gentlement, i fell the Power of Speed right away, as you all know downtown TORONTO it isnt eazy to drive cause bunch of peoples very small path lotta parked-car and peoples jumpin passin in the way, i used to had fun with Taxi/TTC and some of young men with their sporty cute car untill i got merried ;)
The point of saying this cause i think Solara can compete with BMW, Acura RSX, Infiniti G35, Luxus, Accord 2D coupe XLE v6 and the new Nissan Altima 2d coupe v6. I drove many kind of car sport/sedan this is what ive seen by Speedy comparing, im not comparin with the Luxury/Quality or beauty of the car, im tryin to compare the speed.
Lemme name out some of lady sport car like Toyota-Celica, Misubishi Eclipse, Huyndai-Tiburon, Civic-si, maybe to some of you these car are great but to me these cars are weak, yes ive been tested with them, my friend driving a 2004 Celica 5speed, other lady-friend has a Mit-Eclipse v6 2002, a workmate has a Civic-si v-tech, and the Huyndai-Tiburon got burmed by me in High-way (Freeway) hmm the Celica and the Civic seem to be ok but the Tiburon and Eclipse seem like breakin the engine with the noise. I think Eclipse without Turbo = nothin. Its good in USA but not Canada.
Alrite what did i mean i burned out that Tiburon was...here the story.
That summer day was a nice day no wind very nice weather and cleared, i drove my brother inlaw my sister and my wife, so that were 4 persons includin me, we were on high-way with 90k/mph maxed, thats Gardener/DonValley in Ontario, that idiot Tiburon popped up from behind with his fully suit-up car very nice Tiburon mods, my Solara was normal and all Original no mod nothin, 1st of all he cuts off and tried to brakin infront, i was like wat da F is this guy doin, my wife/sister calmed me down and told me just lets it go who cares blah blah, then he pulled back beside me, in highway i couldnt hear what he said but then i figured out he wanted to test somethin, i told sis/bro/wife to Seat-belt and this Tiburon guy wanna to test his new speed somethin like that, i told him OK in action and then we started, his car only 2 persons look like his girlfriend beside him, my car 4 persons mean= slower a bit, seriouly he cant pass me and the noise of his car was like breakin down, we raced about 2/3km and after that i let him pass n i slowed down cause the BI-t-chin of my Wife and my sister, that time we almost reach Don-Valley anyways so i slowed my car, then we merged to Don-valley parkway, and my brother was like, wtf somethin smokin up ahead, i slower more and get close to look, guess what ? it was the Tiburon guy just raced with us, we didnt know what happened to his car, his car smoked in the front of hood near engine parts.
My 99 Solara been in many Winters with Heavy snowtorm, big rain/wind, race and floorin, ofcourse i drive everyday with this car, i drive almost like taxi, untill then my friends says, dam your car still good and strong and it has 200k/m on it, i changed Timing-belt/Water-pump at 130k/m, because of the Hip-Hop dance, i bought a Solara 2001 and gave Solara 99 to my sister. i dont know why its like that to lara99, my Lara2001 was fine smoother than 99lara, when it hit gear 3 and i press deeply the gas oh my god, scared out of myself too man, gear1 = 15km, gear2= 25km, gear 3=40km and it jumped to around 70km in 1/2 seconds, hehe yes in downtown Toronto with this speed can suspend your license, take your car away.
RandySolara
BAN sticked
