SolaraGuy.com • View topic - Manual gearbox feels sludgy in cold weather
Postby hari-bhari » Sun Jan 18, 2009 5:47 pm
It has been unseasonably cold in Atlanta the past few weeks and when I first get in the car, it feels like I am shifting through sludge (which I am assuming is thick, cold oil) for my first couple of shifts. It is all perfectly back to normal within about a minute, or after the 2nd or 3rd shift. Doesn't bother me, just need to know that this is not reason for concern or I have to change to a different weight oil.
hari-bhari
Postby 1gSE » Sun Jan 18, 2009 6:18 pm
normal
Solara-M62 @ 5.5psi
1gSE
Postby ~SolaRaSpeed~ » Wed Jan 28, 2009 10:43 pm
I would HIGHLY recommend Redline MT-90, it will feel good again once you do a drain and fill with about 4.5 qts of this stuff and it's as easy to do as an oil change.
~SolaRaSpeed~
Postby bronzemaxell » Fri Jan 30, 2009 5:14 pm
i've been using redline mt-90 for over a year, and temp here was in single digit once, and been in low teens and twenties F, but i don't feel slugish
bronzemaxell
Postby mazen222 » Sat Jan 31, 2009 1:55 pm
its pretty cold in montreal, and my shift nob is always sluggish when the car is still cold... i beleive its the grease that is supposed to go just below the leather boot. After a couple of shifting (10 min drive) and the car is hot inside, the shifting is normal.... you can try to regrease that area, where the shifter stick joins the rest of the tranny under the leather boot
gl
1999, 5 Speed V6
mazen222
Postby crispone » Sat Jan 31, 2009 1:58 pm
LOL!
This could only come from a WARM-WEATHER driver...
Come live anywhere up here where it gets cold regularly... there are MANY little things you come to "expect"...
Normal.
Postby akora12 » Sat Jan 31, 2009 3:46 pm
I have redline MT-90 as well, and while it's great at cold temps, it's a bit notchy when hot.
Also, I wouldn't think you should be having much problems with your tranny oil in GA. My OEM oil didn't change when the weather was in the double-digit negatives around here.
