SolaraGuy.com • View topic - Secondary 12-volt receptacle is not working
Postby LatinDragonXJC » Tue Jan 20, 2009 11:49 am
My secondary 12-volt receptacle (below the cig lighter) is not working. Is there a fuse that connects to it? Or would I have to swap it out?
LatinDragonXJC
Postby lilm » Tue Jan 20, 2009 1:29 pm
check your cig fuse.
lilm
Postby TLMNICK » Tue Jan 20, 2009 4:19 pm
Check ALL fuses...not just the ones related to cig lighters, etc.
there is also a wire fuse on the outlet itself....sometimes they burn. Its not something you'll be able to tell by looking at it...you'll need either a testlight, or volt meter to confirm.
TLMNICK
