SolaraGuy.com • View topic - HELP!! ENGINE PROBLEMO #2
Postby wid » Wed Jan 21, 2009 8:46 am
2 days ago when i statred up my car she seemed fine but when i put her in to d the engine started to studder real bad. when i accelerate normally on the pedal, i felt her doing the harlem shake, not just once but everytime i give her gas at a decent level. the only way that i can drive her with out any studering is if i gas her as light as possible. u can imagine the comotion i get behind me. so today i took her to the toyo dealer and they said that its has to do with the edu or edr or somthing i dont remember exactly, but he said, the dude said that he can replace the whole thing for 800 smackers. i was wondering could i get it cleaned instead of replaceing the whole thing i dont know too much about cars but i think the old saying the the dealers do over charge and exzagerate. but i dont have that type of mooney yet.two month back my baby did before but not as bad the dealers said that it was damaged wires after they fixed the wires for 88 bucks she was fine but i just want some advice from u TOP DOGS.
wid
Postby LatinDragonXJC » Wed Jan 21, 2009 9:29 am
LatinDragonXJC
Re: HELP!! ENGINE PROBLEMO #2
Postby akora12 » Wed Jan 21, 2009 9:49 am
wid wrote:I FELT HER DOING THE HARLEM SHAKE
If I only had a nickle for every time I've said that...
Postby CamryOnBronze » Wed Jan 21, 2009 10:18 am
:lol: awesome
Postby no_escape » Wed Jan 21, 2009 10:20 am
Have you changed your plugs, plug wires, and ran fuel injector cleaner?
You could also get a second opinion to see if that is the problem.
no_escape
Postby wid » Wed Jan 21, 2009 10:29 am
:agrue: so is there any advice for my problem. I thought i came to the right place for help. :cry:
wid
Postby ASG14 » Wed Jan 21, 2009 10:31 am
^ Yes, but many people will not read posts like that, like me. It makes it harder to read.
ASG14
Postby wid » Wed Jan 21, 2009 10:40 am
oh ill try to consider my audiance
wid
Postby ASG14 » Wed Jan 21, 2009 10:50 am
^ I'm guessing you mean well educated by that.
ASG14
Postby Midias » Wed Jan 21, 2009 10:59 am
Many people who will actually give a helpful response will put a decent amount of time and effort into typing an easy to read and useful post. You should consider doing the same when you post a question it is expected if you want any real help.
Also adding some a decent amount of info would be great, the "HARLEM SHAKE" does not help much. Give some info such as when was your last tune up? Is the check engine light on? If so what is the code? Does it shake at all speeds? Have you made any modifications to the car lately?
So you took it to the dealer, did they give you work order or a piece of paper with the problem written on it? As far as I know the "EDU OR EDR" are not real things, they probably said the ECU and EGR. The EGR can be cleaned easily with some throttle body cleaner. I would suggest buying a manual at a local auto parts store they only cost about $20. Read the manual and learn the location of key parts under the hood. If your ECU is bad (not common) you have to replace it as it cannot be cleaned as it is the computer that controls the car.
caps
Postby jetbtkng » Wed Jan 21, 2009 11:20 am
comon guys lighten up, is this how you treat a new member, he made a simple mistake, so the moddo is nail him to a cross, i like caps makes it easier to read as my eyes arent as good as they used to be, so quit being so bitchie and help the dude for chriss sakes, and take a chill pill :drinking:
Postby Midias » Wed Jan 21, 2009 11:53 am
^ For a guy who likes caps you seem to use very little your self.
Postby 1gSE » Wed Jan 21, 2009 11:54 am
:-? got a CEL?
Solara-M62 @ 5.5psi
1gSE
Postby jetbtkng » Wed Jan 21, 2009 11:58 am
Midias wrote:^ For a guy who likes caps you seem to use very little your self.
well i know some people dont like'm so i try to be respectful, but doesnt mean people should freak out over it either, :drinking:
Postby Midias » Wed Jan 21, 2009 12:02 pm
^ I don't think anyone would care if you used capitol letters and periods in the proper combination when posting. Makes it much easier to read.
