SolaraGuy.com • View topic - brake noise
brake noise
brake noise
Postby solara90 » Thu Feb 05, 2009 5:55 pm
when im at a stop light with the brakes on i hear a hiss, sounds like water running though pipes fast, and once i release the brakes it goes away, but when i go back on the brake it comes right back on?
would this be a leak brake booster or master cylinder?
02 solara 2az
solara90
Postby Jakecallun20 » Thu Feb 05, 2009 6:10 pm
Does the sound stay on the entire time your foot is on the pedal or just while its coming to a stop? and also, is fluid pooling up in your driveway, or is your master cyl reservoir full?
Postby solara90 » Thu Feb 05, 2009 7:00 pm
it stays on the whole time im stopping/ stopped.. i got no dripping and i believe my fluid level is good
02 solara 2az
solara90
Postby Jakecallun20 » Thu Feb 05, 2009 8:44 pm
Well I doubt its a leak, because your car still stops. You'd know if your lines had a leak lol. Are you absolutely sure its coming from the brakes, and your not hearing something else? Something that is too quiet to hear over road noise until your stopped? If its not your lines, and it continues while stopped, I would think that its either your brake booster and there is something off inside it, or its not your brake system.
Postby gnegroni » Thu Feb 05, 2009 8:56 pm
solara90 wrote:it stays on the whole time im stopping/ stopped.. i got no dripping and i believe my fluid level is good
Could it be the brake booster? It happened to several of my cars (none Toyota) although its hiss of air, not "fluid" like water.
gnegroni
Postby no_escape » Wed Feb 11, 2009 9:17 am
It's the brake booster. I have the same issue and had it checked out to be sure.
Before you go and buy the wrong one. There are two different boosters, one for Traction Control and one for no traction control. Right now, I'm going to research if I have TC or not.
no_escape
Postby solara90 » Wed Feb 11, 2009 9:34 am
i dont necessarily need it replaced right away? ill still be able to stop just take longer and be harder correct?
it only seems to do it if i been driving for more than 10minutes also
02 solara 2az
solara90
Postby System_Crash » Wed Feb 11, 2009 9:39 am
Try this, start the car and leave it in park and stick ur head down by the brake pedal and press it with youre hand. If the hissing is comming from this area , more than likley the brake booster is leaking vaccum. Now depending how bad it is you can spray dry-lube (silicone spray) on the rod and seal and the noise will go away. If the leak is bad enough you'll have to replace the brake booster.
Pearl White 2004 Solara V6 90,000 miles
System_Crash
Postby no_escape » Wed Feb 11, 2009 10:12 am
solara90 wrote:i dont necessarily need it replaced right away? ill still be able to stop just take longer and be harder correct?
Mine has been doing it since middle of last year. I would have taken care of it earlier but health issues, of course. Due to health, I haven't driven much... that will soon change in the next months 8)
Yes, it will be harder to brake.
no_escape
Postby gnegroni » Wed Feb 11, 2009 11:48 am
System_Crash wrote:Try this, start the car and leave it in park and stick ur head down by the brake pedal and press it with youre hand. If the hissing is comming from this area , more than likley the brake booster is leaking vaccum. Now depending how bad it is you can spray dry-lube (silicone spray) on the rod and seal and the noise will go away. If the leak is bad enough you'll have to replace the brake booster.
I would say follow his advice but also keep on the lookup for a brake booster. It will go out in due time and we don't want to have any accidents.
gnegroni
hissing
Postby D-money » Sun Mar 01, 2009 10:13 pm
I have the same problem and i can her a hissing coming from the engine bay when i turn off the car and hop out i found a new brake booster on line for 271.00 @partstrain.com that is with shipping tax and core charge
D-money
Re: hissing
Postby TxBmbleBee » Sun Mar 01, 2009 11:20 pm
D-money wrote:I have the same problem and i can her a hissing coming from the engine bay when i turn off the car and hop out i found a new brake booster on line for 271.00 @partstrain.com that is with shipping tax and core charge
im positive you can find one cheaper if you have access to a junkyard
TxBmbleBee
brake booster
Postby D-money » Sun Mar 01, 2009 11:58 pm
Why take the chance with another used one and posably having to do all that work twice the one i told you about comes with life time waranty
D-money
