SolaraGuy.com • View topic - spoiler removal
spoiler removal
spoiler removal
Postby solara90 » Fri Feb 06, 2009 9:13 pm
well, before i rip my trunk apart how is the spoiler mounted, i want to take it off to get the "clean" look but is there bolts that hold it on? will there be holes in the trunk if i take it off?
02 solara 2az
solara90
Postby fzzyrn » Fri Feb 06, 2009 10:56 pm
i vaguely remember there being holes that the spoiler is mounted from. you'll probably have to have them filled.
fzzyrn
Postby ToyoSolV6 » Fri Feb 06, 2009 11:09 pm
hmm, why do you want to take off the spoiler, i personally thinks it gives the solara a cleaner look than not having it at all, every time i see one out on the street i always see it as if it is missing something good. Then again its what you like bro but i beleive it does leave holes, so your going to have to get them filled up.
Postby lilm » Fri Feb 06, 2009 11:45 pm
2 bolt I belive
lilm
Postby Ilovemylara » Fri Feb 06, 2009 11:45 pm
yes there are two holes on the outer edges of either side of the truck lid. you could always redneck it and use jbweld to fill them holes'... j/k
Postby solara90 » Sat Feb 07, 2009 8:30 am
haha or not i guess i'll just not take it off :-(
02 solara 2az
solara90
Postby wekillyou » Thu Feb 12, 2009 11:48 pm
if you do take it off I'll buy it off of you.
wekillyou
Postby Patrik » Sun Feb 15, 2009 10:30 am
there is 4 nuts 10mm size if i remember correctly.. just be carefull when taking them out i broke on stud last time and cause of that i could remove the spoiler.. resone for taking it of.. it was shaking too much cause of the bass... wated to put some padding under it but never got to finishing that.. so thank god for rattles lol
1999 SE V6 5 speed SOLD
Patrik
Postby TLMNICK » Sun Feb 15, 2009 10:47 am
The "clean" look you're after is what you'll get WITH the spoiler. I think these cars look like they're missing something without it.
TLMNICK
Postby LEE337 » Sun Feb 15, 2009 1:31 pm
IMO the Solara Gen 1-1.5 looks beautiful with the stock spoiler. 8)
Postby Chinky420 » Sun Feb 15, 2009 2:21 pm
also, if the stock spoiler has been on for several years, there may be some etching in the paint from where the spoiler touched the trunk.
similar to how you get minor paint etching of the emblems after you shave them off the trunk.
to me, the gen 1/1.5 solara looks funny without the oem spoiler.
Chinky420
Postby DiamondPearlSolara01 » Mon Feb 16, 2009 10:17 pm
you have to leave it on otherwise, personally, I think is looks bad.
2001 Solara V6 SLE
TRD - K&N - Alpine - Infinity
Postby Ilovemylara » Mon Feb 16, 2009 10:31 pm
yes it will usually have etching, My sunroof even has a slight pattern around where the visor used to be.
Postby Toy1mzfe » Tue Feb 17, 2009 12:27 am
i also dont think the car looks right w/o it.....
but.. if u do remove it, u can use rubbing compound to take off color difference but cleaning up the areas around it.
