SolaraGuy.com • View topic - How to replace oil pan gasket..
Postby TOYODRIVER01 » Fri Feb 06, 2009 10:03 pm
Looking for instructions to replace oil pan gasket..... :roll:
TOYODRIVER01
Postby solara90 » Sat Feb 07, 2009 8:32 am
drian the oil pan, remove all the bolts holding it on, take it off remove old gasket, and reverse the steps
02 solara 2az
solara90
Postby mazen222 » Thu Feb 12, 2009 5:42 pm
i have the toyota maintenant manual electronic version... i saw that somehwere, let me know if u still need it
1999, 5 Speed V6
mazen222
Postby 5842solara » Thu Feb 12, 2009 6:06 pm
solara90 wrote:drian the oil pan, remove all the bolts holding it on, take it off remove old gasket, and reverse the steps
depending how old the gasket is.. it may not be that simple.
when you take the gasket.. visually inspect the pan. if you see old gasket stuck you want to scrape it off. try not to scratch the oil pan though.
use a carbon scraper or something.
if you leave parts of the old gasket on. you may experience some leaks.
good luck.. pretty simple though
5842solara
Postby Ilovemylara » Thu Feb 12, 2009 6:08 pm
v6 or I4?
Postby TOYODRIVER01 » Thu Feb 12, 2009 11:26 pm
its a 4cyl.
would i need to put gasket maker on as well?
TOYODRIVER01
