SolaraGuy.com • View topic - pinout/voltage for speedo sending unit
Postby therieldeal » Mon Feb 09, 2009 6:46 am
I'm swapping a camry/solara trans into a different car. I'm considering running an autometer electronic speedo, rather than trying to adapt my original cable driven speedo with an mr2/alltrac sending unit.
Does anyone know the pinout for the camry/solara sending unit? I'm assuming it has ground, + voltage, and signal, but which pin is which and what voltage does it operate on?
Thanks!
therieldeal
Postby corlon » Mon Feb 09, 2009 10:04 pm
for a 99 solara with a 3.0 v6 it looks like the speed sensor only has 2 wires. red for 12 volts power in and green for signal out.
NiCe
corlon
Postby therieldeal » Tue Feb 10, 2009 8:17 am
i could have sworn it had 3 pins, i'll take a look again this afternoon
either way, i need to know which pin is which in order to wire things up
therieldeal
Postby ozone » Wed Feb 11, 2009 5:35 pm
There are 3 wires. They are purple, blue and red with a blue stripe. Pictures to follow.
ozone
Postby ozone » Wed Feb 11, 2009 6:08 pm
Sorry for the blurry picture. My scanner is not connected so I photographed it. I tried to make it clearer with the notes. The sensor is circled in green and you can see the labeled wires. It looks like there are two red with a blue stripe wires, but that is actually just to indicate the differences between the automatic and manual models. They ultimately go to the "gauge" fuse.
This one came out clearer and you can see where the other two wires go in the combination meter:
ozone
