SolaraGuy.com • View topic - Req: Front Strut mounts replacement tutorial
Postby mazen222 » Mon Feb 09, 2009 7:36 am
Has anyone replaced their own front strut mounts?
I have purchased them from ebay (including the bearings) and I will be replacing them during this week with a mechanic friend.
Not that I do not trust him, but i would prefer to have instructions on how to replace them the proper way.
Do any of you have tutorial for that or maybe something from a manual?
If not, maybe i could provide some pics and creat a tutorial for the next person who will attempt this.
Thanks!
1999, 5 Speed V6
mazen222
Postby Midias » Mon Feb 09, 2009 8:08 am
After using the search function and searching for the word strut in the tutorial section of the gen 1-1.5 section I found some threads of days gone by that might help the thread titled "Front strut installation instructions
" might be very helpful. But tutorial improvements are always welcome.
http://solaraguy.com/viewtopic.php?t=30 ... ight=strut
http://solaraguy.com/viewtopic.php?t=36 ... ight=strut
finally
http://www.albinoblacksheep.com/flash/posting
Postby mazen222 » Mon Feb 09, 2009 9:42 am
thx, this will definitley help
I was hoping for scan from hayes manual or something like that. Looks more complicated than i thought.
THanks
1999, 5 Speed V6
mazen222
Postby TMMK Toy » Mon Feb 09, 2009 10:33 pm
I noticed in the last tutorial there is talk of the isolator. Was that just supplied with the TRD susepsnion or something that is used for OE? When I did my suspension I got new strut mounts for the front but it was only the mounts, I had to reuse the old bearings. I guess this is normal?
TMMK Toy
Postby ASG14 » Wed Feb 11, 2009 12:58 pm
ASG14
ASG14
Postby TMMK Toy » Wed Feb 11, 2009 7:00 pm
I think my front strut mounts were aligned properly. Everything seemed lined up right. If it werent, would I have been able to reinstall the suspension with the spring even seated right? Just want to make sure I didnt do something wrong. The car handles good to me so I dont think so. A lil noisy but I attribute that moreso to the stiffer suspension
TMMK Toy
Postby mazen222 » Wed Feb 11, 2009 7:14 pm
i bought front struts with the bearings... it was like 30 bucks extra, so its worth it.
i will be installing them soon, cant wait
1999, 5 Speed V6
mazen222
Postby mazen222 » Wed Feb 11, 2009 7:18 pm
wow, beatifull! thanks for the link ASG14!
1999, 5 Speed V6
mazen222
Postby akora12 » Wed Feb 11, 2009 7:48 pm
TMMK Toy wrote:I think my front strut mounts were aligned properly. Everything seemed lined up right. If it werent, would I have been able to reinstall the suspension with the spring even seated right? Just want to make sure I didnt do something wrong. The car handles good to me so I dont think so. A lil noisy but I attribute that moreso to the stiffer suspension
The margin for error with the alignment of the mounts is fairly small, but it could still cause some noise if off by a degree or so. Mine are correct and still produce an occassional knock in certain instances. Bad bearings and/or lack of grease in the bearing cup usually causes noise.
Concerning the isolator, that's just the upper and lower rubber rings that the spring rests on to buffer it from the shock, which is OEM.
Postby mazen222 » Fri Feb 13, 2009 5:12 pm
well, after all, i didnt wanna go through the mess of getting the spring compressors and waisting 4 hours on them and engining up not installing them correctly.
so i went to a mechanic, i asked if he would install them for 100$ (i know it cost more than that). At first he refused, then after some give and take he agreed.
and happy to say that waw! no more noise comming from the front... makes the car feels soooo much better! no more knoking and crap on each bump!
i just had to tell someone :P 160$ for the parts
1999, 5 Speed V6
mazen222
