SolaraGuy.com • View topic - Audio Help Needed - lights are dimming with cap & Optima
Postby solara1989 » Mon Feb 16, 2009 9:43 am
Hello everybody. im having a lil' problem with my audio electric system. i have a 3000 watts power acoustik mono block amp with 2 12 kickers L5 with a 10 farad tsunami capacitator and the lights still dim. at first i thought it was the battery that wasnt powerful enuogh so i upgraded to optima dry cell yellow top, but the lights still dim. Anyone has any suggestions?
Thanx everybody.
2000 Solara SLE V6 Diamond White
solara1989
Postby Midias » Mon Feb 16, 2009 10:03 am
What alternator are you running? Chances are the stock one cannot power all that it is only 80 amps.
Postby solara1989 » Mon Feb 16, 2009 10:27 am
Midias wrote:What alternator are you running? Chances are the stock one cannot power all that it is only 80 amps.
yeah, i still have the stock alternator.
I guess that could be the problem.
solara1989
Postby Midias » Mon Feb 16, 2009 10:29 am
^ I bet with a little research you could find a cheap and easy solution for a much better direct replacement alternator but to be a nice guy here is the link
Postby 5842solara » Mon Feb 16, 2009 10:44 am
depending how you want to do this..
alternator is a good way.. that is a lot of watts
also
you can try ground your battery better. put 1 or 2 i guess 0-4 gauge wires.. and ground that. try to keep them short. maybe a foot or less.
that helped my civic..
(civics only have a skimpy ground wire..)
solara's ground wire is decent
5842solara
Postby redgen1 » Mon Feb 16, 2009 2:07 pm
i'm running 1500 watts rms and about 2500 max with a 3 farad cap and i still dim. new alternator for this spring
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby Midias » Mon Feb 16, 2009 2:42 pm
5842solara wrote:depending how you want to do this..
also
Just remember if you replace the stock gnds run new wires to the stock ground points or bad things can happen.
Postby Yanks0114 » Mon Feb 16, 2009 9:16 pm
solara1989 - I edited your title to provide a description and so it didn't just say "HELP!!!"
Postby Eye8Pussies » Mon Feb 16, 2009 9:23 pm
as mentioned- a good ground, but more importantly, a higher output alternator
OR run a couple more batteries
Postby Solara08861 » Mon Feb 16, 2009 9:37 pm
Here is a cheaper alternative.
I actually running this one as my second battery.
I'm in the process on getting a second one or the bigger one.
http://www.batcap.net/800.html
Solara08861
Postby Aotoyota » Mon Feb 16, 2009 10:09 pm
consider getting a battery isolator too only one battery dies and you're not stuck.
my vote is for the alternator ! have you upgraded the cables portion from the alt to the battery + ground?
Aotoyota
Postby Ilovemylara » Mon Feb 16, 2009 10:24 pm
doesnt the sienna have a stronger alternator? You could try a swap
Postby SpeedySolara » Tue Feb 17, 2009 12:49 am
I think the Highlander or rav4 alternator puts out about 150 and its a direct fit. DONT quote me on this one. I've read it somewhere before but dont know where
SpeedySolara
Postby Midias » Tue Feb 17, 2009 5:00 am
I think this is the correct one and the solara alternator can be used as the core. I believe it nets you about 50 amps over stock.
Duralast Import / Alternator
for a 2001 Toyota Truck Highlander 4WD
About this product:
Part Number: 12299
Weight: 13.01 lbs.
Warranty: LLT
Note: 130 Amp optional
Premium reman
Pricing:
Unit Price:
$139.99
*Core Value:
$62.00
Total Price:
$201.99
Postby LEE337 » Tue Feb 17, 2009 7:38 am
Im trying to get the funds together for a new alt as well.
Im gonna go with one off a Sienna XLE AWD, which has 150 amps.
