SolaraGuy.com • View topic - question???
question???
question???
Postby showlara » Sat Feb 21, 2009 10:27 pm
does anyone know how to turn off the headlights from running in the daytime?
showlara
Postby Ilovemylara » Sat Feb 21, 2009 10:42 pm
You know you posted this thread twice? well, for starters, what year is your solara?
Postby SdeA » Sat Feb 21, 2009 10:44 pm
Pop the hoood, and unplug the grey connector on the passenger side.
SdeA
Postby showlara » Sat Feb 21, 2009 11:02 pm
thanks very much, just did it
showlara
Postby Skew » Sat Feb 21, 2009 11:10 pm
Be sure if your light sensor on your dash is not connected also.
Skew
Postby showlara » Sun Feb 22, 2009 1:12 am
how would u disable the light sensor?
showlara
Postby LEE337 » Sun Feb 22, 2009 1:42 am
The dash light sensor is not as important as the DRL. I take it your running HIDs? I am too. My dash sensor is still connected and it only turns your headlights on when its dark. The DRL has to be disconnected to run HIDs because of the low power. The dash sensor does not.
BUT if you want to disconnect it, pop up the sensor on the dash, follow the wire and disconnect it.
