SolaraGuy.com • View topic - whats happening to my headlights?
Postby rewmomi » Sat Feb 28, 2009 10:28 pm
so my high beams work but my low beam only works on the driverside not on the other so i thought it was the socket i changed it and spliced it with a new pigtail and it still did not work i then though it was a relay then i when i changed it it still did not work i changed the fuses and it still does not work what should I do?
rewmomi
Postby ASG14 » Sat Feb 28, 2009 10:36 pm
Did you change the bulb?
ASG14
Postby Mr_Krispy1183 » Sat Feb 28, 2009 10:52 pm
What Adam said.
Postby Ilovemylara » Sat Feb 28, 2009 10:54 pm
that should have been the first thing to check lol
Postby ToyoSolV6 » Sat Feb 28, 2009 11:25 pm
^x2
would really suck if you did all that work and you didnt try changing the bulb lol
Postby Ilovemylara » Sun Mar 01, 2009 12:29 am
^haha
Postby rewmomi » Sun Mar 01, 2009 7:30 am
well yeah if course i tried that but just did not mention it lol
rewmomi
Postby drewcrane » Sun Mar 01, 2009 8:12 am
wow so is it fixed?
"its a vanishing point thing you wont understand"
drewcrane
Location: 13.7 sec.s @bandimere ,5800 ft above sea level
Postby rewmomi » Sun Mar 01, 2009 8:51 am
no i am just saying that that was the first thing i checked before doing all that to my car
rewmomi
Postby rewmomi » Tue Mar 03, 2009 3:45 pm
so no one knows what it could possibly b?
rewmomi
Postby Ilovemylara » Tue Mar 03, 2009 5:07 pm
take two wires and termporarily hook them to the point where you spliced the new socket, and run it directly to the battery, if it works then theres probably a short somewhere in your oem wiring.
