SolaraGuy.com • View topic - sunroof problem?
sunroof problem?
sunroof problem?
Postby Ilovemylara » Sun Mar 01, 2009 1:03 am
When I press the slide button on the switch, the sunroof will "pop" DOWN as it normally does, only followed by a loud SLAM and the whole headliner shakes. then it continues sliding back into the headliner normally after that. Does anyone else have this problem? how did you fix it? thanks 8)
Postby Ilovemylara » Sun Mar 01, 2009 2:04 pm
btw it seals just fine, but i worry it will break soon
Postby crispone » Sun Mar 01, 2009 2:46 pm
Don't remember on the gen 1-1.5, but there should be a TSB on the gen 2's, wherein it GROWLS as you actuation it to open sometimes. Mine does it about 20-30% of the time... but I just never did anything about it, and now I have nearly 100k on the car anyway!
g/l
-crisp
:evilbat:
Postby mazen222 » Sun Mar 01, 2009 3:59 pm
weird... check if theres something blocking the tracks...
gl
1999, 5 Speed V6
mazen222
