SolaraGuy.com • View topic - Starting problem
Starting problem
Starting problem
Postby mazen222 » Sun Mar 01, 2009 8:06 pm
When i start my car it turns on normally, but the engine trembles/jumps the first 2 seconds, then Rpm goes up to 1.5 untill the car is hot and drops gradually to 0.8 when temperature is good.
On the other hand... when i drive fast and abuse the car. If I turn it off and try to turn it back on withing 2 minutes, it will turn on, Rpm goes up then drops back down to 0.2 and the car shuts off... unless i give her some gas.
Any ideas on what that might be? I havent had any tuning done for a while... old spark plug... old timing belt... none sythetic oil
99 V6 5speed, 210,000 km
1999, 5 Speed V6
mazen222
Postby D-money » Mon Mar 23, 2009 12:54 pm
clean your throttle body disconnect intake from thrttlr body hold flap open and spray liberally with carb and choke cleaner alot of carbon build up will cause that i ended up using the whole can and now it runs great
D-money
