SolaraGuy.com • View topic - metal radiator hose
metal radiator hose
metal radiator hose
Postby rewmomi » Tue Mar 03, 2009 3:12 pm
I was wondering if you guys ever had seen those universal radiator hoses my top one like ripped i dont know how but im doing a radiator flush and changing the hose but i was wondering if i get that metal one would it be ricey looking. The only reason why im considering this is because ive notice that my radiator hose in the past seems to bend up and stuff.
rewmomi
Postby ThatVietGuy » Tue Mar 03, 2009 3:30 pm
You wouldn't want a metal radiator hose. The hose has to be able to bend and twist along with the engine; metal does not have these properties...
ThatVietGuy
Postby YESCA » Tue Mar 03, 2009 3:37 pm
Oh contraire....
http://store.summitracing.com/partdetai ... toview=sku
And yes it would look ricey, unless you had everything else in your engine chromed out.
YESCA
Re: metal radiator hose
Postby youngblood » Tue Mar 03, 2009 3:40 pm
rewmomi wrote:I was wondering if you guys ever had seen those universal radiator hoses my top one like ripped i dont know how but im doing a radiator flush and changing the hose but i was wondering if i get that metal one would it be ricey looking. The only reason why im considering this is because ive notice that my radiator hose in the past seems to bend up and stuff.
You probably could use a metal hose designed for hot rods. There are rubber hose sections at each end of the metal tubing. That is why you can use it on an engine which vibrates and moves around a bit. I think it would look kinda ricey, but it sounds like you want it more for functionality than looks. If you are having problems with your rubber-style hose, I'm not sure why. Is it the exact part number for your car? Was it installed correctly (pushed all the way on the water neck and radiator)?
I say go with the factory stuff. :drinking:
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby youngblood » Tue Mar 03, 2009 3:41 pm
YESCA wrote:Oh contraire....
That's the stuff! There is rubber under those end caps, btw.
youngblood
Postby rewmomi » Tue Mar 03, 2009 3:44 pm
yeah well ill go factory for now and if it continues to bother me then ill consider getting it.
rewmomi
