SolaraGuy.com • View topic - Airbag Light
Airbag Light
Airbag Light
Postby rossman945 » Thu Mar 05, 2009 3:44 pm
Well I have a 99 solara V6 down here in Florida and this winter when it got cold, my airbag light would stay on after start. By cold, I mean like 40s and 50s in the morning. The other day, it turned on while driving and would come on and off randomly. Has anyone had similar problems, and is there anything I should watch out for. I'm going to get the code tested tomorrow. I think its just a bad sensor.
Thanks,
Ross
rossman945
Postby jetbtkng » Thu Mar 05, 2009 4:03 pm
had a sensor go bad on mine had to replace it, kinda rare tho..... :drinking:
Postby rossman945 » Thu Mar 05, 2009 4:15 pm
What was the price for the part and install?
rossman945
Postby jetbtkng » Thu Mar 05, 2009 4:19 pm
i don't remember, i think a couple hundred bucks, dealer did the fix, i'll see if i can find the receipt......... :drinking:
Postby jetbtkng » Thu Mar 05, 2009 4:31 pm
i called penske toyo, i couldnt find my reciept but its around $500, but you might just have to reset it, dam i have a bad memory thought it was less, thats what tom told me over at penske, the price depends on what sensor it is....... :drinking:
Postby aleki2424 » Thu Mar 05, 2009 4:46 pm
The light can be triggered by a several factors.Anything from the circuit under your seat malfunctioning to having a faulty deployment module in your column, or even the sensors themselves. either way, it is not
possible to pinpoint the issue without having the codes pulled. And most likely a dealer will have to pull them since most obd II scanners like those in auto zone will not do a thing in the sense of diagnosis.
I had to change the column module , in my case, and that cost about 300 just for the part.
Since your light is intermittent, i think that you either have a loose connection, or one of the above is occurring. GL.
aleki2424
Postby rossman945 » Thu Mar 05, 2009 5:10 pm
Thanks guys, yeah Toyota wanted 35 bucks just to scan the code and I wasn't too crazy about that, I'll bring it buy Autozone and see what happenens, more than likely I will end back at Toyota.
rossman945
Postby Aotoyota » Thu Mar 05, 2009 6:23 pm
you might try and check the service manual, when my passenger light came on the manual said to disconnect battery for 30min
might b e worth a shot.
btw i have a gen 2
Aotoyota
Postby D-money » Thu Mar 05, 2009 7:28 pm
it happened to me to but it was just a bad connection under the seat so check your plugs wont hurt to try
D-money
Postby rossman945 » Fri Mar 06, 2009 5:07 pm
Thanks for the help.
rossman945
