SolaraGuy.com • View topic - How do you remove rear light bulb holder?
Postby Jeffrey Olson » Sat Mar 07, 2009 2:55 pm
The subject says it all. I've got a 99 SE and the chilton manual says to rotate the bulb holders in their sockets and remove. Well, I can't get them to rotate, and I can't for the life of me see how to pry those suckers out.
Any help???
Jeff...
Jeffrey Olson
Postby ThatVietGuy » Sat Mar 07, 2009 3:01 pm
Do you mean the light for the license plate lights? I have no idea which lights you're referring to.
ThatVietGuy
Postby Jeffrey Olson » Sat Mar 07, 2009 3:02 pm
I mean the brake light and tail light sockets. The bulb goes in from the outside, but to get it in you have to remove the socket, not the lens.
Jeffrey Olson
Postby Jeffrey Olson » Sat Mar 07, 2009 3:04 pm
Sorry for being obtuse. My rake light burned out and I need to replace the bulb...
Jeffrey Olson
Postby SdeA » Sat Mar 07, 2009 3:25 pm
where do you live? maybe some local SG could help you out :)
SdeA
Postby ThatVietGuy » Sat Mar 07, 2009 3:57 pm
I'm messing with a spare tailight I have and all I can say is make sure you're turning it the right way :-?
And you also need to put in a fair amount of force to turn the bulb.
ThatVietGuy
Postby SdeA » Sat Mar 07, 2009 10:31 pm
^^ yea its not that hard to take out the bulb all you have to do is twist it...make sure you twist it in the right direction.
SdeA
Postby T-solaRa-D » Tue Mar 10, 2009 6:11 pm
ThatVietGuy wrote:I'm messing with a spare tailight I have and all I can say is make sure you're turning it the right way :-?
I actually used a pair of pliers to gain leverage and put some force into it. I had the same thoughts of it being stuck in there for good.
Try Chillax......
T-solaRa-D
Postby ToyoSolV6 » Tue Mar 10, 2009 6:51 pm
Just give it a good tug, it should be able to come off. Well when i changed mine it wasnt really that difficult.
