SolaraGuy.com • View topic - HELP- HISSING SOUND
HELP- HISSING SOUND
HELP- HISSING SOUND
Postby D-money » Sat Mar 07, 2009 10:37 pm
I hear hissing sound after i turn off my car like an air leak but i have checked all my vacuum lines and no leaks any ideas?
D-money
Postby SdeA » Sat Mar 07, 2009 10:38 pm
^^ Devon I think thats sound is coming from your intake.
SdeA
Postby D-money » Sat Mar 07, 2009 10:44 pm
it makes that noise for about 30 sec after i turn off the car.also I noticed that now when i turn off my car with my foot on the brake the peddle pushes my foot up its wierd. any ideas
D-money
Postby solara90 » Sun Mar 08, 2009 7:49 am
its most likely your power brake booster emptying out after you turned off the engine, which would push your foot up because you are loosing the vacuum that powers the booster
02 solara 2az
solara90
Postby Ilovemylara » Sun Mar 08, 2009 8:51 am
Sounds like a brak ebooster problem. If its emptying out its vacuam after you turn it off, thats not good. My car still has a little bit of vacum pressure in the brake booster even a day after i turn it off.
Postby D-money » Sun Mar 08, 2009 7:43 pm
thanks guys
D-money
Postby Mole » Mon Mar 09, 2009 8:16 am
you know... you're the first who made a post in aftermarket that i have to move into gen1 stock talk...
POST IN THE CORRECT FORUMS!
Postby D-money » Mon Mar 09, 2009 11:21 am
sorry didnt do it on purpose
D-money
Postby gnegroni » Mon Mar 09, 2009 12:08 pm
Yep, check the brake booster for leaks.
gnegroni
Postby D-money » Tue Mar 10, 2009 12:09 am
I ordered a new brake booster it cost me 271.00 I will be instaling it on wed thanks for all the help.
D-money
Postby Toy1mzfe » Tue Mar 10, 2009 1:08 am
have u made sure that the BB was the problem?
Postby D-money » Tue Mar 10, 2009 1:34 am
yes i have done alot of trouble shooting and in the repair manual that i just got it says -hold down the brake and turn off the car if the pedal does not move then the booster is fine.but my pedal pushes up quikley when I turn off the car,also i noticed a new symptom today.when the car was running i got down on my knees and pushed and held the brake with my hand and i could hear the hissing sound from behind the fire wall.so i did a google search with what i knew and it all pointed to the brake booster
D-money
Postby D-money » Wed Mar 11, 2009 5:13 pm
instalation complete and all problems gone.thankyou everyone
D-money
Postby solara90 » Thu Mar 12, 2009 2:02 pm
mine is going out too.. i just dont want to replace it cost too much
02 solara 2az
solara90
Postby D-money » Thu Mar 12, 2009 4:49 pm
mine got to the point where the check engin light would come on and tell me it was running to lean because of the vacuum leak
D-money
