SolaraGuy.com • View topic - driver side headlight condensation
Postby mightymouse402 » Sun Mar 15, 2009 12:34 am
Hello all,
I bought some black housing headlights recently, had no problems whatsoever until today. I noticed there was a bit of condensation inside of the driver side headlight. It kind of looked like cold air was getting in somewhere but I'm not sure. It went away after I had my headlights on for a while when I would drive. Is there any way I can fix this problem?
Any helpful responses are appreciated. Thanks! =o)
That's what she said...
mightymouse402
Postby ThatVietGuy » Sun Mar 15, 2009 2:54 am
The surefire way is to open the headlight and re-seal it yourself.
ThatVietGuy
Postby Ilovemylara » Sun Mar 15, 2009 8:32 am
take the headlight off, and run a bead of clear silicone sealant.. not caulk, all the way around it, covering the entire lens seam.
Postby mightymouse402 » Sun Mar 15, 2009 10:16 am
can i buy the clear silicone sealant from like an autozone or something? or do i get from a hardware store?
mightymouse402
Postby BLACK V6 » Sun Mar 15, 2009 10:39 am
I know any home improvement store carries it. At least the bigger ones do like Lowe's and Home Depot.
BLACK V6
Postby mightymouse402 » Sun Mar 15, 2009 10:43 am
thanks for the responses guys. keep em coming if you've got anymore helpful ones, i'll probably go out and buy some silicone sealant today.
mightymouse402
Postby Got2XLR8 NYX » Sun Mar 15, 2009 12:55 pm
The back of the Headlights have Vents... thats how i think moisture gets into the housing so don't try to reseal it you'd be wasting your time. I found the vents when I did the Black Housing DIY and dunked the housing in a tub of water to check for any leaks and then discovered them.
5Speed 2000 SC V6 @ 4.5PSI
Got2XLR8 NYX
Postby mazen222 » Sun Mar 15, 2009 1:05 pm
i have the same issue with the driver side clear corner lens i bought off someone on this forum... im waiting untill the weather is nice and i will located the hole by putting it halfway into water and looking where water will come in, then i will use silicone like the the other guys suggested to clog it up.
Good luck!
1999, 5 Speed V6
mazen222
