SolaraGuy.com • View topic - HESITION TO LOWER LARA
Postby wid » Thu Mar 19, 2009 9:10 am
HEY U GUYZ.... i was going to work and i parked my car by a curve and ever since i parked my car its ben raining hard, so after work i wen to start up my car and nuttin it was dead,the car in terior lights were dull and the ingiton sequnce was not working all i herd was click click click. wen went to pop the hood i noticed a pool of water under my car alomost tuching the bottom of the engine. i got a friend to give me a jumpand it was ok . but i was thinking about lowering it , and if i did lower my car i think the rain water would have got in the enigine and all...i want o lower my lara but im not too sure the rain flood wud be a good sighn for my cars health
:x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x
wid
Postby cklinh » Thu Mar 19, 2009 11:06 am
s0 w3r3 yOu Lo0k1n6 fOr @dV1C3 0r SoMeTh1n6?!?
cklinh
Postby Ilovemylara » Thu Mar 19, 2009 11:25 am
although the engine may have been nearly in the water, it wouldnt cause any harm, maybe a little surface rust. It would have to be flooding like 3+ feet of water to mess up your engine. Unless you have a cold air intake. I say LOWER IT..
Postby LEE337 » Thu Mar 19, 2009 3:20 pm
I say lowere it and park somewhere else. :D
It doesnt sound like the water was your problem. Its sounds like your alt or battery is the problem. Like Christian said your car would have to be in atleast 3 feet of water or enough to submerge your tail pipe. Check for hood leaks.
Postby Gibson99 » Fri Mar 20, 2009 10:18 am
LEE337 wrote:would have to be in atleast 3 feet of water or enough to submerge your tail pipe. Check for hood leaks.
wow, is your tailpipe 3 feet off the ground? :drinking:
j/k most water under 1 foot deep won't hurt a car even if you drive through it. if you have a CAI then yes it could suck that water into the engine, so don't drive thru deep water w/ a CAI. just parking there is fine, even if the water IS touching the oil pan.
hood leaks? the hood doesn't seal anything. it helps aerodynamics and keeps pedestrians out of your engine bay. ;) it also protects all the wires and hoses in there from road debris. the "hood seal" at the back of the engine bay is only there to help force air through the engine bay while driving for proper circulation. it has nothing to do with keeping out rain/water. when you drive in the rain, water goes thru the radiator and hits everything in the front of the engine bay - exhaust, alternator, a/c compressor, etc... and when you hit a puddle, the rest of the engine bay gets wet. go drive through a big puddle then pull over and pop the hood if you don't believe me.
Gibson99
