SolaraGuy.com • View topic - v6 clutch hydraulic system question
Postby therieldeal » Thu Mar 26, 2009 4:43 am
So a few months back I purchased a 99 camry v6 manual transmission from someone here on the forum. I'm using it as part of a transmission conversion into a totally different vehicle.
I had a quick question about the clutch linkage. Inline on the clutch hydraulic line there is a block/valve of sorts. What is this and what does it do? I was thinking it must be a damper of some sort, perhaps to slow down the release of the clutch. Do you think I should I retain it in my install or eliminate it?
The car is street driven but also goes to the drag strip whenever possible. It runs low 12's now when I can keep the transmission together, aiming for 11.51 eventually with the camry trans (no cage).
Thanks!
therieldeal
Postby Eye8Pussies » Thu Mar 26, 2009 7:30 am
it's an accumulator, but it doesn't seem to serve much purpose. I think that part of the design is so that it makes the system more serviceable by connecting shorter pieces of hard line
as for, do you need it? no, you don't. when I did my tranny swap, my accumulator and attached lines were so rusted together that I just by-passed it using a single hard line straight from the soft clutch line to the slave cylinder
Re: v6 clutch hydraulic system question
Postby CASTRO » Thu Mar 26, 2009 8:30 am
therieldeal wrote:So a few months back I purchased a 99 camry v6 manual transmission from someone here on the forum. I'm using it as part of a transmission conversion into a totally different vehicle.
Thanks!
more info please! I'm interested your car now that its broken the 13sec and even 12 range! insane!
CASTRO
Postby therieldeal » Thu Mar 26, 2009 10:04 am
It’s a 95 ford escort GT...
The engine is a 1.8 dohc out of a 93 mazda 323 GTR - which was a jdm only street-legal rally car. I'm running 23 pounds of boost on megasquirt 2, 320whp 325wtq.
My best time is 12.28 at 117.2, but my friends managed to miss that run with the camera :(. Once I get the E153 in there, spend a little more time on my tune, and try some real bias-ply slicks... I should be in the 11's no problem.
The problem I'm having is the components in the stock tranny are simply not strong enough. I have a quaife LSD installed, so that’s fine... but most recently I stripped all the teeth off of 3rd gear. Not even during a shift... just driving along, mid-gear at full boost on a smooth road.
Heres a video:
http://www.youtube.com/watch?v=KRNs9HsjYD0
therieldeal
Postby Gibson99 » Thu Mar 26, 2009 10:19 am
I'm curious to know how you will mount the toyota tranny to the mazda engine. If I'm not mistaken, that's basically the same 1.8L "BP"engine found in the 94-06 mazda miata. custom welded-on bellhousing? sounds like a beast!
Gibson99
Postby therieldeal » Thu Mar 26, 2009 10:33 am
Yes, it's the same basic engine as the miata. The 91-96 escort GT came stock with a BP, as did the protégé lx from 90-94 and the kia sephia from 95-97. The gtr engine was essentially "built" from the factory though, and of course included a sizeable turbo :D.
I'll be using an adapter plate between the block and tranny, custom mounts, a hybrid clutch, etc etc etc. Should be quite a project!
therieldeal
