SolaraGuy.com • View topic - CEL again
CEL again
CEL again
Postby solara90 » Thu Mar 26, 2009 3:15 pm
well i had my cel go on back in February and it was P0420 catalyst below efficiency.. and it went off about a week ago
and today it popped on again so i went to the local parts store and got it checked out and it was P0171 System too Lean (Bank 1).
i haven't done anything to try and fix either of these codes ive searched around but my conclusion has come to and 02 sensor or the MAF... any other opinions
i don't seem to have anything wrong with performance either, just seems a little bit laggy on acceleration sometimes
02 solara 2az
solara90
Postby Dawgz » Thu Mar 26, 2009 3:19 pm
Clean ur maf, reset the ecu...should go away...hopefully...
Postby ClassySolaraGuy » Thu Mar 26, 2009 3:23 pm
Have your O2 sensors checked out. If you replace your cat things will be great but if you have a faulty O2 sensor throwing incorrect information to your system...Your new cat is going to die out quicker than normal.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby D-money » Thu Mar 26, 2009 6:51 pm
i had that code it was a vacuum leak coming from my break booster if it is too lean it means un metered air is getting into your engine check your vacuum lines
D-money
Postby solara90 » Thu Mar 26, 2009 8:24 pm
so it could be a intake manifold gasket too
02 solara 2az
solara90
Postby D-money » Thu Mar 26, 2009 8:57 pm
true
D-money
Users browsing this forum: Google [Bot] and 31 guests
