SolaraGuy.com • View topic - throttle body coolant bipass
Postby D-money » Mon Mar 30, 2009 8:20 pm
ok so i was on a web site today and i saw a mod i think it is a stock mod so i am posting here any way what was done was the coolant lines to the throttle body that keep it warm in extreem cold weather where capped off and re routed back to the engine to prevent the coolant from passing through the tb it said by doing that it would add any where from 4 to 8 hp does anybody have an opinion about this mod to the 1mz .here is a link of what i am talking about http://www.installuniversity.com/instal ... bypass.htm
D-money
Postby ThatVietGuy » Mon Mar 30, 2009 8:25 pm
It's been discussed. Doesn't do anything.
ThatVietGuy
Postby ThatVietGuy » Mon Mar 30, 2009 8:27 pm
ThatVietGuy
Postby D-money » Tue Mar 31, 2009 10:17 am
thanks im still having trouble with my searches
D-money
Postby Toy1mzfe » Tue Mar 31, 2009 10:30 am
^^^our search system kinda suck tho.
Postby Midias » Tue Mar 31, 2009 10:56 am
^ Never had a problem with it?
Yea the TB bypass is about as good as those IAC chips. In other words there is no hp gain to get from it. It may help a little when it is very hot outside but the best you could hope for is to not have as much of a HP drain as the car warms up. But it can be don for about 3 dollars in parts so give it a try.
Postby Eye8Pussies » Tue Mar 31, 2009 11:58 am
that, and it becomes a lot less work to remove the TB for the ones of us who constantly take our cars apart! lol
Postby Mr_Chunkz » Tue Mar 31, 2009 6:09 pm
i have it done to my car and it doesnt do anything at all.
Hahahaha -_-''
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Chinky420 » Wed Apr 01, 2009 12:53 pm
it's good to prevent heatwash of your aftermarket intake for about 10 minutes.
but once your engine block heats up, it's pretty much gonna absorb that heat into the TB through the intake piping and your intake plenum.
but in texas, where frozen TB's aren't EVER a concern, there's no reason to have coolant going through there (esp in >100*F weather), just be sure to let your car idle for about 5 minutes if it's near freezing temperatures.
but overall, no real noticable consistant gains. just makes it easier to mess around with the TB if you're installing something like a spacer. there's a slight inconsistent gain, when the temp gauge shows 1/4 hot (i guess the block is warm on the inside from the coolant, but the exterior of the block and all the extra parts havent heated up yet). nothing measurable, just something that can be felt occassionally (like a little hp easter egg). but this gain goes away after the temp gauge is at half mast
Chinky420
