SolaraGuy.com • View topic - CEL & Traction Control Light
Postby Omes01SLE » Thu Apr 02, 2009 1:19 pm
Started the car today and both these lights came on at the same time - haven't had time to check the actual code yet... any ideas of what it could be? Strange that they both came on together, no? thx.
2001 Stock Solara Auto.
Omes01SLE
Postby ASG14 » Thu Apr 02, 2009 5:48 pm
Um, how can we help you IF YOU DON'T KNOW THE CODE?
ASG14
Postby Omes01SLE » Thu Apr 02, 2009 7:04 pm
sorry, I meant to imply if the two (CEL & Traction Control) lights coming on together at the same time would have indicated something right away that I wasn't aware of - I'll pull the code this weekend, and repost.
Omes01SLE
Postby Chinky420 » Thu Apr 02, 2009 7:56 pm
CEL and Trac, when lit together, indicate a redundant fault.
it could be for the same code (single code), or for multiple codes.
i've had both of mine lit for a while...when i pull the neg terminal off the battery, it'll reset (no lights on either), then after about 70 miles, the CEL will come back on.....if i try to light up the tires after the CEL is on, the Trac system will try to activate, but will ultimately disable itself (thus illuminating both CEL and Trac)
get the code pulled, it could be something serious, or it could be something minor....we'll never know until you get the code.
Chinky420
