SolaraGuy.com • View topic - Throttle Body Spacers ?
Postby Robert » Sun Apr 12, 2009 11:53 am
does anyone know if there is one made for the solara??
are there any specs on these ie: metal used, & dimensions?
I've got a few connections and can possibly get these made very inexpensively.
Pictures would be helpfull too :D[/i]
Robert
Postby SleeperSolara » Sun Apr 12, 2009 11:56 am
I just used Helix Tacoma throttle body spacer.
Postby Robert » Sun Apr 12, 2009 12:12 pm
did it make a difference?
Robert
Postby sydemoid » Sun Apr 12, 2009 1:24 pm
been usingmine for 2 years now, I feel an increase in throttle response in the mid range rpms, and it seems to increase the flow at higher rpms. Gas mileage is good as well. I would say for an NA engine, its worth the buy.
sydemoid
Postby panic » Sun Apr 12, 2009 2:45 pm
Yes, there's a difference.
Your bank balance is lower.
http://victorylibrary.com/mopar/3MZ-c.htm#TBS
panic
Postby Robert » Sun Apr 12, 2009 3:40 pm
thanks panic
Robert
Postby panic » Sun Apr 12, 2009 4:16 pm
On a highly developed engine using a tuned intake length (and different cams), changing the intake length will bump the peak torque around slightly - but typically it will not raise the actual torque, and a spacer will reduce the effective RPM, thus lowering peak power.
In a VVT engine with a few thousand hours of research and dyno time in it - don't you think one of the few thousand Toyota engineers would have said "why are we killing ourselves developing more cams - let's just put a spacer in here?"
There really aren't any easy and cost-effective ways to increase the efficiency of any of these engines. Those products are made by a process that exists in the cosmetics industry: it doesn't matter if it does anything, because no one will buy it twice, and few will admit they made an error (classic example: when your girlfriend was horribly butchered at the beauty salon, she still tipped the beautician, didn't she? And she still went back there the next time?).
What does matter is that it sounds like it will do something ("this miracle cream reduces the appearance of fine lines due to aging"). They also learned from the cosmetics people that appearance and packaging is even more important than function: a Clairol box and bottle costs more to make than the product inside. Therefore: billet and blue-anodized.
Speed equipment is quite different. Someone invents something that works, and he discovers that he will make more money making them for 1,000 people than he could by winning races against them.
Vic Edelbrock: first the successful product, then the marketing.
panic
Postby SleeperSolara » Sun Apr 12, 2009 6:55 pm
Yeah there was a difference.
A slight difference.
Postby trd4life » Mon Apr 13, 2009 2:37 pm
My S/C Solara showed a substantial increase in peak airflow on the SAFC with the addition of the spacer, i used a Airaid spacer for the 3.4 tacoma
