SolaraGuy.com • View topic - new master cylinder problems
Postby solara90 » Wed Apr 15, 2009 8:21 pm
well i put my new master cylinder in and now my brake light came on, is it a bad master cylinder? i did reattach the sensor wire
02 solara 2az
solara90
Postby Midias » Wed Apr 15, 2009 8:21 pm
Add some more brake fluid
Postby solara90 » Wed Apr 15, 2009 8:30 pm
it was full, didnt make it go off, never use my parking brake either, and i didnt set it either, so that can be it
ah, i also started the car before it was hooked up.. i forgot to but i plugged it right away.. would that be why?
02 solara 2az
solara90
Postby ~SolaRaSpeed~ » Wed Apr 15, 2009 8:47 pm
yeah see if you can't clear the code with either a scan tool (best option b/c you can see why it is showing) or pull the negative on the battery. If it comes back then you have a problem.
~SolaRaSpeed~
Postby akora12 » Wed Apr 15, 2009 8:52 pm
I assume you fully bleed the cylinder? I believe it needs to be bleed separately from the lines.
Postby solara90 » Thu Apr 16, 2009 7:02 am
yes i did bench bleed it
akora12 wrote:I assume you fully bleed the cylinder? I believe it needs to be bleed separately from the lines.
02 solara 2az
solara90
Postby ChrissyD123 » Thu Apr 16, 2009 7:03 am
break fluid
</SolaraGirl>
{15inch JL sub w/ 1000 JL Watt Amp.... Stock engine, but clean Lara}
ChrissyD123
Postby Midias » Thu Apr 16, 2009 7:08 am
ChrissyD123 wrote:break fluid
Beer?
Postby ChrissyD123 » Thu Apr 16, 2009 7:21 am
fu*k dat. Brake. :0
</SolaraGirl>
ChrissyD123
Postby JvR » Thu Apr 16, 2009 8:35 am
maybe a stupid thing....but have you checked the brake lights.
One time i had the same problem ...my 3th brake light was broken. :roll:
JvR
