SolaraGuy.com • View topic - What is the "Rear main seal" OEM name?
Postby mazen222 » Thu Apr 16, 2009 5:09 am
Im having my clutch changed so I thought changing the rear main seal would be a good idea... this guy quoted me 90$ for the rear main seal part only!!
So im thinking of buying this full gasket kit on ebay for 90$... i just need to make sure tha the rear main seal is included, so which one is it from the below?
Parts Include:
2- Head Gkt. (Graphit)
2- Valve Cover Gkt.
2- Intake Manifold Gkt.
2- Exhaust Manifold Gkt.
24- Valve Stem Seals (Viton)
2- Cam Seal
1- Throttle Gkt.
4- Exhaust Pipe Rings
1- Fuel Injector O Ring Set
1- AGR Gkt.
6- Spark Plug Tube Seals
16- Grommets
1- Conversion Set (Lower Set)
Thanks!
1999, 5 Speed V6
mazen222
Postby unbalancedwood » Thu Apr 16, 2009 6:00 am
He could be talking about the seal for transmission to engine...or rear valve cover seal...find out exactly which one hes talking about...
unbalancedwood
Postby Gibson99 » Thu Apr 16, 2009 6:39 am
even at toyota the rear main is only like a 30 or 40$ part.
i don't see the rear main oil seal (aka rear main crank seal) in that list you posted. never heard of an AGR gasket... maybe he meant EGR? also "conversion" set? what's that?
Gibson99
Postby mazen222 » Thu Apr 16, 2009 9:09 am
Just spoke with toyota.
The real part name is called "rear main crank seal" with PN 90080-31053
its 32$ tax in
Im just gonna order that from the dealer and forget about the ebay kit.
Thanks for the inputs
1999, 5 Speed V6
mazen222
Users browsing this forum: Google [Bot] and 28 guests
