SolaraGuy.com • View topic - weird thing when braking
Postby solara90 » Mon Apr 20, 2009 4:55 pm
well when im coming to a stop at a light or stop sign, just before im about to fully stop my rpms will go up to around 1,000 and then dump back down to around id say 700- 650 and kinda chug, and then itll go back up to normal idle. I'm thinking it could be my spark plugs? Any one else have ant ideas
02 solara 2az
solara90
Postby grnsolara » Mon Apr 20, 2009 5:03 pm
Plugs or plug wires definitely sound reasonable. If you don't find a problem there, I found mine in coil packs. Are you getting a check engine for a misfire?
Fuel filter or fuel pump are other possibilities.
I read forums more than I talk. /shame
grnsolara
Postby solara90 » Mon Apr 20, 2009 5:07 pm
i haven't got a CEL, i got some plugs laying around ill replace em' and see what happens
grnsolara wrote:Plugs or plug wires definitely sound reasonable. If you don't find a problem there, I found mine in coil packs. Are you getting a check engine for a misfire?
02 solara 2az
solara90
Postby grnsolara » Mon Apr 20, 2009 5:18 pm
Ya w/ no CEL yet that rules out o2 sensor and EGR valve. I was having a similar problem, and it wound up being the front bank o2 sensor and EGR valve especially at idle and lower rpms. However, it threw a CEL.
Check it out, and tell me how it goes.
grnsolara
Postby Midias » Mon Apr 20, 2009 5:19 pm
How old are the plugs and what brand?
Also how many miles n the car and have you ever cleaned the throttlebody?
Postby solara90 » Mon Apr 20, 2009 5:20 pm
around 97,000, no idea on the plugs bought the car back in September, and no no the TB
Midias wrote:How old are the plugs and what brand?
02 solara 2az
solara90
Postby grnsolara » Mon Apr 20, 2009 5:20 pm
oh...very good point Midias. Check the throttle plate too!
grnsolara
Postby Midias » Mon Apr 20, 2009 6:00 pm
grnsolara wrote:oh...very good point Midias. Check the throttle plate too!
I would clean the throttle plate and the entire throttlebody to get the idle air control.
Postby solara90 » Mon Apr 20, 2009 6:09 pm
a couple of questions, does it matter if i clean the whole throttle body with MAF cleaner, or use carb cleaner? can i use carb cleaner on the IAC also? and do i remove the IAC from the TB?
02 solara 2az
solara90
Postby Midias » Mon Apr 20, 2009 6:17 pm
solara90 wrote:a couple of questions, does it matter if i clean the whole throttle body with MAF cleaner, or use carb cleaner? can i use carb cleaner on the IAC also? and do i remove the IAC from the TB?
I would use throttlebody cleaner to clean the throttlebody and IAC. and no you do not have to remove the IAC but it would not hurt.
Postby ~SolaRaSpeed~ » Mon Apr 20, 2009 7:09 pm
clean your TB and MAF (clean the maf with maf cleaner). Next, do a tune up (plugs, wires, fuel filter, seafoam) and then if that doesn't do it you might have a vacuum leak.
~SolaRaSpeed~
Postby Mole » Mon Apr 20, 2009 11:18 pm
is your AC on ?
Postby Akfahad » Tue Apr 21, 2009 7:24 am
when I had that problem, ended up being my IAC valve. But would definitely go first with what's being recommended....clean the TB, etc.
Postby solara90 » Tue Apr 21, 2009 7:33 am
nope its only like 40 outside.. my heat was on :roll:
Mole wrote:is your AC on ?
02 solara 2az
solara90
Postby makethemusic72 » Wed Apr 22, 2009 8:17 am
I had the same problem, I just cleaned out the throttle body with some throttle body cleaner and reassembled, and voila! my car idles correctly and evenly. took me 5 minutes!
makethemusic72
